insert leaders at the coordinate use the text and coordinates from an excel file
Inspection2.resolution
Observer Observer
Observer
Observer
I'm trying to insert a bunch of leaders with text using easting and northings as x an y. I've tried the following formula:
=CONCATENATE("(command ",CHAR(34),"_MLEADER",CHAR(34)," ",CHAR(34),B4,",",C4,CHAR(34)," ",CHAR(34),D4,",",E4,CHAR(34)," ",CHAR(34),A4,CHAR(34),")")
but I keep getting
Command: (command LISP command is not available.
Command: "_MLEADER" Unknown command ""_MLEADER"". Press F1 for help.
Command: "2.1,3.4" Unknown command "1,3.4"". Press F1 for help.
Command: "3.6,3.9" Unknown command "6,3.9"". Press F1 for help.
Command: "ID1")
Unknown command ""ID1")". Press F1 for help.
I'm not to experienced with AutoCAD so appreciate any help. Thanks.
Sea-Haven
Worked for me.
You can do this direct from excel reading the cells. Yes requires code, happy to discuss further. This is Autocad controlling the excel range input and returns a list of cells.
hosneyalaa
Observer
Observer
Unfortunately I was using autocad lite at work, it worked perfectly on 2022 version. All sorted now and have just saved so much time!!
ВeekeeCZ
In LT, you should be able to use a script. The syntax could look something like this
MLEADER 2.1,2.4 3.6,3.9 "ID1";
MLEADER 2.1,5.4 3.6,3.8 "ID2";
... but I don't know how to end the text editor... try to ask in LT forum.
