Lisp for Purge dialog box..
rob.aHH2T8
rob.aHH2T8
What's is the lisp that will automate my purge: 1-open purge, 2-'purge all', 3-close the box?
cadffm
You can't control dialog windows by lisp, but you can use command "-PURGE" to do what you want!
In Lisp you can controle all commandline commands by using Lispfunction COMMAND
Note: Script,Macro,Command&sendcommand will start -PURGE, also while you trying to start PURGE command in automations.
Script:
-PURGE
ALL
no
Menumacro:
-PURGE;all;*;no
Lisp(command
(command "-PURGE" "all" "*" "no")
Sebastian
pendean
Community Legend
Community Legend
rob.aHH2T8
I don't understand.
I have 'purge' as a quick command: cc
I then manually click on the 'purge all' and hit close.  If it's anything more than 3 clicks, it's not automatic enough.
cadffm
@rob.aHH2T8  schrieb:
I don't understand.
I offered three ways, if you don't understand none of them - it isn't much 😄
Okay, you have to use command -PURGE to automate your wish to purge all.
You can create and use a script, or a menumacro, or action macro or any kind of api /programming
and if you are not familiar to all of them:
Do you know how to save and autoload a lisp file?
If yes, use this code:
(defun c:CC nil (command "_.-PURGE" "_all" "*" "_no")(princ))
As first test: Copy this line and paste it into your commandline, after that - try the new CC command
Sebastian
RobDraw
You can replace this with Alt+A.
That brings it down to 2 clicks.
Rob
Sea-Haven
If you get serious about purge often it needs to run say 3 times. If you have CIV3D need to use a separate purge command before purge.
If you make a startup.lsp you can have a lisp defun that is your purge, use Appload save to Start up Suite. My startup lisp has like 30 defuns. Or add to the default Acadxxxx.lsp ones.
(defun c:PPP ( / )
(command "-purge" "A" "*" "N")
(princ)
The purge for civ3D is purgestyleandsettings, can make a massive difference to size of dwg.
