control dimensional constraint from lisp
Shay.Gaghe
Shay.Gaghe
hi
i have a drawing with dimensional constraint applied.
now , a dimensional constraint can behave as either a constraint or as a reference,
user have to set the Reference property to Yes or No.
so actually i want to control this property from lisp or any other language.
is it even possible?
Thnks
Shay
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
ВeekeeCZ
(setpropertyvalue (car (entsel)) "DimConstrReference" 1)
Sea-Haven
Lee-mac has an excellent Dynamic block suite of defuns. Setproperty is not available for Bricscad.
So you can pop dcl's asking for input d1 & say d2, set visibilty states and much more. The latter put all the visibilty values into a dcl so when its inserted the correct visibilty is displayed saves having to go to the little triangle and select.
(defun LM:setdynpropvalue ( blk prp val ) ; block as vl object - prp is property name d1 - val is new value
You could do something like this
