Visual LISP, AutoLISP and General Customization
How to make a userform.
1 REPLY 1
Dan-Rod
150 Views, 1 Reply
Hello, I have an excel in which I fill in data to be able to convert it to a .scr file since it is a routine to convert files with multiple sheets from pdf to dwg.
The problem is that I have to be modifying the excel, go to notepad and save in .scr, I would like to see if someone can help me know how to have a userform in which I feed only the data that makes the routine work, in this case it would be 2, the size of the sheet and the file path, the excel is already formulated.
1 REPLY 1
Sea-Haven
in reply to: Dan-Rod
Three answers, are you aware you can copy a excel column of cells and paste to command line, no script required.
A excel VBA macro can write a file based on column values just google write file column cells Excel VBA, I am sure an answer is there.
Last answer can read a Excel file from CAD, so would read the cell data and use that in a lisp command. Just reading rows of data.
So your choice.
AutoCAD Inside the Factory
