I have a question while executing the viewport command.
nychoe1
nychoe1
Hello.
I created two viewports using the vports command in an AutoCAD model.
When I zoom in one of the viewports, the other viewport zooms in the same way.
That is, the two viewports zoom at the same time.
Originally, when I zoom in one viewport, the zoom screen should not be executed in the other viewport...
Why is that? Why does this symptom occur? I am curious.
Haven't you ever had this experience?
Kent1Cooper
Can you post a small drawing file containing two Viewports that behave in this way?
Kent Cooper, AIA
Moshe-A
@nychoe1  hi,
Make sure UCSFOLLOW is set to 0 in each viewport - does that solve the issue?
Moshe
pendean
Community Legend
Community Legend
@nychoe1 .... and get in the habit of locking your viewports too when you are not in need to change the ZOOM of the content.
nychoe1
I solved it.
I turned it off because the third-party program had a zoom link function.
Thank you.
