Hello, I have an excel in which I fill in data to be able to convert it to a .scr file since it is a routine to convert files with multiple sheets from pdf to dwg.
The problem is that I have to be modifying the excel, go to notepad and save in .scr, I would like to see if someone can help me know how to have a userform in which I feed only the data that makes the routine work, in this case it would be 2, the size of the sheet and the file path, the excel is already formulated.
