- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all. Given this points as variants
(IF (= 70-DXF-DATA 37) ;ang 3 pt (PROGN (SETQ EXT-LIN1-PT (VLA-GET-EXTLINE1ENDPOINT DIM-OBJ)) (SETQ EXT-LIN2-PT (VLA-GET-EXTLINE2ENDPOINT DIM-OBJ)) (SETQ ANGLEVERTEX (VLA-GET-ANGLEVERTEX DIM-OBJ)) ) ;end PROGN );end if
Is there a similar vl function to get distances between each variant points pair, like the lisp function DISTANCE pt1 pt2 , given pt's as
(setq pt1 (list x1 y1 z1)) ;and (setq pt2 (list x2 y2 z2)) (setq pt1-pt2-dist (distance pt1 pt2))
