How to get distance between 2 points as variants
devitg
devitg
Hi all.  Given this points as variants
(IF (= 70-DXF-DATA 37) ;ang 3 pt
     (PROGN (SETQ EXT-LIN1-PT (VLA-GET-EXTLINE1ENDPOINT DIM-OBJ))
            (SETQ EXT-LIN2-PT (VLA-GET-EXTLINE2ENDPOINT DIM-OBJ))
            (SETQ ANGLEVERTEX (VLA-GET-ANGLEVERTEX DIM-OBJ))
       ) ;end PROGN
     );end if
Is there a similar vl function to get distances between each variant points pair, like the lisp function DISTANCE pt1 pt2 , given pt's as
(setq  pt1 (list x1 y1 z1)) ;and
(setq pt2 (list x2 y2 z2))
(setq pt1-pt2-dist (distance pt1 pt2))
Accepted solutions (3)
paullimapa
komondormrex
hi,
get coordinates as lists
     (SETQ EXT-LIN1-PT (VLAX-GET DIM-OBJ 'EXTLINE1ENDPOINT)
           EXT-LIN2-PT (VLAX-GET DIM-OBJ 'EXTLINE2ENDPOINT)
       	   distance ext_pt1_pt2 (distance EXT-LIN1-PT EXT-LIN1-PT)
     ) ;end SETQ
devitg
@komondormrex   @paullimapa .  so there is no  a Distance function to be used to variants.
I will try both samples you give me.
komondormrex
as a variant  is a special data type that can contain any kind of data except fixed-length string data and user-defined types, there cannot be such function as distance for two variants, may they even be points.
