Create Paths Autocad
My_Civil_3D
My_Civil_3D
I have a lisp File that created paths in the Support folder settings. the issue is that it only created the first path and not all of them is there a specific way of loading more than one path? this the code i'm using: i have removed my actual paths for privacy reasons
(DEFUN AddSupportPath (dir / tmp Cpath)
  (VL-LOAD-COM)
  (SETQ	Cpath (GETENV "ACAD") tmp (STRCAT ";" dir ";"))
  (IF (NOT (VL-STRING-SEARCH dir cpath)) (SETENV "ACAD" (STRCAT Cpath ";" dir)))
  (PRINC)
(AddSupportPath "PATH 1")
(AddSupportPath "PATH 2")
(AddSupportPath "PATH 3")
Civil 3D Certified Professional
Sea-Haven
Have a look at this example
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
;make new support paths exist + new
(setq paths (vla-get-SupportPath *files*))
(setq newpaths "P:\\autodesk\\supportfiles;P:\\autodesk\\lisp;P:\\autodesk\\fonts;")
(setq newpath (strcat newpaths paths))
(vla-put-SupportPath *files* newpath)
My_Civil_3D
thank you this worked, just one question. what is the correct wording to get the trusted path?
My_Civil_3D
i see it also created duplicate support files, but managed to add a condition to see if it exists, i also have a question regarding creating buttons and a toolbar with lisp, can i inbox you
Sea-Haven
1st the easy one its not really all that secure if you can change it easily.
(setq oldtrust (getvar 'trustedpaths))
(setq newtrust (strcat oldtrust ";" "L:\\Autodesk..."))
(setvar 'trustedpaths newtrust)
 Send me a PM re make a toolbar. I use the make a custom mnu method very easy using notepad.
