How can I run the code with command GCVERTICAL?
穎
穎
Have anyone know this code do not work? Thanks
(setq En (entsel)) (Command "._GCVERTICAL" En)
This code can work:
(Command "._GCVERTICAL" (setq En (entsel)))
ВeekeeCZ
Try just a point.
(setq e (entsel)) (command "_.gcvertical" (cadr e))
穎
It also can not work.
ВeekeeCZ
It does work for me.
Or you can try to use the osnaps... (osnap (cadr e) "_nea")
calderg1000
Regards @穎
Try this code
;;It works for both options.
(Command "._GCVERTICAL" "_pause" )
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
