Need lisp to draw 3D Capsule along selected line/s.
Superbob3D
Superbob3D
Hello!
I am hoping someone out there would be willing to create a Lisp routine for me. I think it's pretty straight forward, but I'd rather not have to spend the time if someone experienced with such things can give me a hand.
I'm looking for a lisp routine that will draw 3D solid "Capsules" along selected lines. The capsule would be a comprised of a cylinder that runs length of the line, with spheres on either end (with all 3 separate solids "union"-ed together). The routine needs to prompt for the radius of the solid (i.e the radius of the cylinder and the two spheres). Ideally the new solid/s will be placed on the "current" layer.
I found this lisp routine, "Curve2cylinder_english_v2.lsp", in another thread today, which gets me close (it draws a cylinders along selected lines). I'm guessing this can just be modified. I just need it to add spheres to the end/s of the cylinder/s (using the same radius) and unionize it.
Thank you!
Bob
Sea-Haven
Why not extrude along PATH it's in built, and add sphere at ends, do you really need code ?
Are you experienced in working in 3D, adding 3d objects ?
If you do want code then write down the steps that is your lisp sequence.
Kent1Cooper
Adding the SPHEREs at the ends and the UNIONing of them with the cylinders to my routine in that topic [which remembers your specified diameter], I get this [lightly tested]:
(vl-load-com)
(defun C:CYLRE (/ ss rad ent start end ssc) ; = CYLinder with Rounded Ends
  (initget (if *tubedia 6 7)); no 0, no negative, no Enter on first use
  (setq *tubedia
    (cond
      ((getdist
          (strcat
            "\nDiameter of Tubular Cross-Section(s)"
            (if *tubedia (strcat " <" (rtos *tubedia) ">") ""); offer default only on subsequent use
          ); strcat
        ); getdist
      ); User-gives-distance condition
      (*tubedia); Enter for default on subsequent use
    ); cond
  ); setq
  (setq rad (/ *tubedia 2))
  (prompt "\nTo make tubular extrusions along paths,")
  (setq ss (ssget '((0 . "*POLYLINE,LINE,ARC,CIRCLE,ELLIPSE,SPLINE"))))
  (repeat (sslength ss)
    (setq
      ent (ssname ss 0)
      start (vlax-curve-getStartPoint ent)
      end (vlax-curve-getEndPoint ent)
    ); setq
    (command
      "_.ucs" "_ZA"
        (mapcar '+
          (getvar 'lastpoint)
          (vlax-curve-getFirstDeriv ent (vlax-curve-getStartParam ent))
        ); mapcar & UCS
      "_.circle" "0,0" rad
      "_.ucs" "_previous"
      "_.extrude" (entlast) "" "_path" ent
    ); command
    (setq ssu (ssadd (entlast)))
    (command "_.sphere" "_non" start rad)
    (ssadd (entlast) ssu)
    (command "_.sphere" "_non" end rad)
    (command "_.union" ssu "")
    (ssdel (ssname ss 0) ss)
  ); repeat
  (princ)
); defun
Do you need Undo-Begin/End wrapping, and/or *error* handling to ensure resetting of the UCS?  Prevention of selection of paths on locked Layers?
[I was going to ask whether it should check for closed objects, and do only the extrusion and skip the spheres, but in the end it doesn't matter.]
Kent Cooper, AIA
Superbob3D
Kent,
Wow! Perfect! Thank you SO much!
Bob
