Lookup Table
Lookup Table
ebarlevi
Lookup Table
ebarlevi
I have a dynamic block in my DWG.
The block has a lookup table value (it appears in the properties palette)
I need to retrieve the value from the block by using a lisp function.
need help please.
Eitan
ВeekeeCZ
Start with posting a dwg with the block to take a look.
ebarlevi
Attached
ebarlevi
Attached
Thanks.
Eitan
hak_vz
@ebarlevi Check this link
Miljenko Hatlak
ВeekeeCZ
You can also use simple
(getpropertyvalue (car (entsel)) "AcDbDynBlockPropertyLength")
to see all the properties available
(dumpallproperties (car (entsel)))
ebarlevi
Fantastic !
Thank you so much,
Eitan
