HELP TO MODIFY LISP (SELECTED BLOCK NAME TO SELECTED TEXT VALUE)
Dear All,
a small modification to be done in followig code. The below code can match the sorce text value to destination text value. The modifcation I need is to match block name value to selected text value.
Lisp Code 1 for reference:
(defun c:MT() (setq entt (car (entsel "Select source text:")))
                        (setq enttx (entget entt))
                        (setq txt (assoc 1 enttx))
                        (setq entd (entget (car (entsel "Select destination DIMENSION:"))))
                        (setq dtx (assoc 1 entd))
                        (setq vij (subst txt dtx entd))
                        (entmod vij))
Or other code I have, that can match text value to block name value.
(defun c:RNB
       (/ *error* _strip ssText ssBlock newBlockName blockName acDoc)
  (defun *error* (msg)
    (if     acDoc
      (vla-endundomark acDoc)
    (cond ((not msg))        ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))       ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                           ; Fatal error, display it
    (princ)
  (defun _strip      (string)
    (foreach char '("<" ">" ":" "\"" "/" "\\" "|" "?" "*")
      (while (vl-string-search char string)
            (setq string (vl-string-subst "" char string))
    string
  (while
    (and
      (princ "\nSelect text: ")
      (setq ssText (ssget ":S:E" '((0 . "MTEXT,TEXT"))))
      (princ "\nSelect block to rename: ")
      (setq ssBlock (ssget ":S:E" '((0 . "INSERT"))))
      (/= (setq      newBlockName
                         (strcat
                           (_strip (vla-get-textstring
                                         (vlax-ename->vla-object (ssname ssText 0))
              (setq    blockName (vla-get-effectivename
                                        (vlax-ename->vla-object (ssname ssBlock 0))
      (not (tblsearch "block" newBlockName))
     (progn
       (vla-startundomark
             (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
       (vla-put-name
             (vla-item (vla-get-blocks acDoc) blockName)
             newBlockName
       (prompt (strcat "\nBlock \""
                               blockName
                               "\" renamed to \""
                               newBlockName
T.Brahmanandam
marko_ribar
https://www.cadtutor.net/forum/topic/66097-help-to-modify-lisp-selected-block-name-to-selected-text-...
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
But Not working Sir
dbhunia
@Anonymous wrote:
Dear All,
                        (entmod vij))
Try this.......
(defun c:MT()
(setq entt (car (entsel "\nSelect source text:")))
(setq txt (cdr (assoc 1 enttx)))
(setq entd (entget (car (entsel "\nSelect Block:"))))
(setq dtx (cdr (assoc 2 entd)))
(if (/= dtx txt)
(progn
(command "_.rename" "_block" dtx txt)
(princ "\nBlock Name Changed")
(princ)
(princ "\nBlocks have the same name.")
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Kent1Cooper
@Anonymous wrote:
.... The below code can match the sorce text value to destination text value. The modifcation I need is to match block name value to selected text value. ....
If I understand correctly, I think some are misinterpreting.  The wording "match ... source ... to ... destination" means, I believe, to take content from  the source object [the Block name] and impose it on  the destination object [the Text], not the other way around as some suggestions appear to work.  If that's right, this does so [in very simplest terms, without verifying selection of the right kinds of things, etc., but all that can be added if it does what you want]:
(defun C:BN2T (/ blkname txt); = Block Name {to} Text
  (setq
    blkname
          (car (entsel "\nSelect Block whose name is to become {M}Text content: "))
    txt (car (entsel "\nSelect {M}Text to make its content the Block name: "))
  (vla-put-TextString (vlax-ename->vla-object txt) blkname)
It assumes a new-enough version of AutoCAD that the EffectiveName property exists for Blocks, whether Dynamic or ordinary.
Kent Cooper, AIA
dbhunia
Hi Kent,
You are right, I became little confused, the requirement ts "selected block name to selected text value".
@Anonymous wrote:
Dear All,
                        (entmod vij))
Hi T.Brahmanandam,
This is a small modification of your code.....
(defun c:MT()
(setq vij (subst (cons 1 dtx) txt enttx))
(entmod vij)
Now its your choice which one you take ..........
Debashis Bhunia
