MULTIPLE LAYERS TURNING OFF BY SELECTING MULTIPLE ELEMENTS BY CROSS WINDOW
Hi helpers,
I need a lisp for that can turn off multiple layers, by selecting multiple elements in different layers.
T.Brahmanandam.
Accepted solutions (4)
dbhunia
Check this.......
(defun C:DEBA ( / )
(setq selectionset (ssget))
(repeat (setq N (sslength selectionset))
(setq Data (ssname selectionset (setq N (- N 1))))
(setq EntityData (entget Data))
(setq Lay_Name (cdr (assoc 8 EntityData)))
(setq layobj (tblobjname "layer" Lay_Name))
(vla-put-LayerOn (vlax-ename->vla-object layobj) 0)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Moshe-A
@Anonymous hi,
have you tried LAYOFF command?
moshe
dbhunia
If you want to turn off the layers by window selection then go through the code.....
otherwise go through "Layoff" command by selection an object of each layers.....
Debashis Bhunia
Moshe-A
@dbhunia
if user just press enter to (ssget) or by mistake, what would happened to your code?
are you sure you can use (vlax-ename->vla-object) without loading ActiveX?
moshe
Thank you for smart and immediate reply Sir.
