Message 1 of 12
08:42 AM
First, I think it would be helpful to explain my workflow. I have searched through the forums but couldn't find anything quite like what I need. I am new to lisp but know enough to modify existing codes, so I don't mind tinkering with the code. I'm here to learn as well. If you have any questions for me, please send them my way. Thanks!
Workflow
1. BEDIT, Select Block.
2. Within Block Editor, I select the attributes and change the Text Style from "RomanS to XXX-ARIAL.
3. Close Block Editor.
4. ATTSYNC.
Known Issues
1. XXX-ARIAL Text Style not in every .dwg. I often add this Text Style through Design Center.
Other
- Would like to automate these tasks.
- If there is a better solution than a lisp, I'm definitely open to suggestions. My goal is efficiency.
- The office I work in is updating their standards, so this process needs to be done in hundreds of drawings.
