Help to Modify Linexp.lsp to keep Layer, Color, line weight and Line Type
Message 1 of 26
Hi again Family 🙂
I need some help with the Linexp.lsp. when exploded, It changes the custom Lines to color White and changes line weight to 0.00.
Is there a way to retain the original types when using Linexp.lsp?
The Line that i Linexp should stay at: Misc Layer, color bylayer, lineweight bylayer and Linetype name is GUY_CABLE.
Thank you sooooo much for any help if possible 🙂
Replies (25)
Message 21 of 26
Lisp attached
Message 22 of 26
Thank you everyone! I was able to convert macro to Lsp routine. Everything works perfectly thanks to everyone here giving me the support I needed 😊👍
Message 23 of 26
Moshe-A
@Anonymous  hi,
i still think that transfering the shape (shx) file is the better solution. cause the way you handle it force you to 'demage' your drawing which i want to believe you do not want to?!
Message 24 of 26
i agree but the customer has express no interest in accepting the shape file 😞
I was able create a macro that piggybacks off the original Linexp command to set all properties as they should be after exploding is done.
here's the lisp routine:
(DEFUN C:xx ()
(C:linexp)
(COMMAND "_CHPROP" "previous" "" "P" "C" "BYLAYER" "LA" "MISC" "LT" "CONTINUOUS" "LW" "BYLAYER" "")
(PRINC)
Message 25 of 26
Moshe-A
@Anonymous ,
just thought you might be intersted in this:
AutoCAD has a beautiful command (long time ago) called SETBYLAYER, it sets everything (or only selected objects) to be bylayer - try it 😀
Moshe
Message 26 of 26
Good Morning @Moshe-A 🙂
Can you help with this? or maybe shoot me into the right direction. i created a post but wasnt sure if that was the correct forum to post in. Can you take a look please. i need some help with a lisp modification
Thank you sir!
Post is here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-to-modify-polyinfo-lsp/td-p/900...
