Vlax-create-object examples
jtoverka
jtoverka
I have already read the help file - vlax-create-object web help
I know you can do the following:
"WScript.Network"
"Scripting.FilesystemObject"
"WbemScripting.SWbemLocator"
"Excel.Application"
"Access.Application"
"Visio.Application"
"Word.Application"
I would like the complete list of objects I can interface with. I understand that any microsoft application can be interfaced with. This has been extremely helpful. How do I find more?
dlanorh
Set a variable name to the created object.
This creates a vbscript regex object
(setq regex (vlax-create-object "VBScript.RegExp"))
Then use the vlax- dump-object
      (vlax-dump-object regex T);; The T (true) tells it to list the objects properties and applicable methods
      (vlax-release-object regex);; when finished release the object
You can do all this from the command line. Output from the dump-object method goes to the text screen.
I am not one of the robots you're looking for
ronjonp
Maybe THIS will help you find program ID's.
jtoverka
A user named MP posted here on December 12, 2016, 12:16:42 PM
(defun _FindProjIDs ( pattern )
    (   (lambda ( pfx sfx pattern )
            (vl-sort
                (vl-remove-if-not
                    (function
                        (lambda (x)
                            (and
                                (eq 'str (type x))
                                (wcmatch (strcase x) pattern)
                    (mapcar
                        (function
                            (lambda (x)
                                (vl-registry-read (strcat pfx x sfx))
                        (vl-registry-descendents pfx)
        "HKEY_CLASSES_ROOT\\CLSID\\"
        "\\ProgID"
        (strcase pattern)
e.g.
(_FindProjIDs "*objectdbx*") ;; I don't have 3D max
    "ObjectDBX.AxDbDocument.17"
    "ObjectDBX.AxDbDocument.18"
    "ObjectDBX.AxDbDocument.19"
    "ObjectDBX.AxDbDocument.20"
It appears that this information is stored within the registry and that this AutoLISP routine finds this information. Thank you very much for pointing me in the right direction.
ronjonp
Glad to help 🙂 .. btw 'MP' is Michael Puckett .. he's a hella smart dude!
please, help me
how to link tekla and visual lisp
(vlax-creat-object Tekla.Structures) -> nil
(vlax-creat-object Tekla.Structures.dll) -> nil
_netload file_path(dll file path)  ->error
> v.b code
reference Tekla.Structures.dll (add)
using tekla.structures;
how th link tekla ~~!!!1
help me please
