Help to Modify PolyInfo.lsp
Good Morning Family,
I need some help.
Im using the PolyInfo.lsp from Lee Mac and its GREAT!
I just need some help to modify it. Too much info is shown and needs to be slimmed down to suit my needs.
Please see DWG and Screen shots below for the L-Mac lsp generation outcome vs the one i modified by deleting columns in CAD. (trying to avoid the deletion in CAD part :))
PolyInfo lisp table shows:
SEG / START X / START Y / END X / END Y / WIDTH 1 / WIDTH 2 / LENGTH / CENTRE X / CENTRE Y / RADIUS
What I would like the lisp to show:
SEG / LENGTH / TOTAL ANGLE OF ARCH
Total Angle is not included in this lisp 😞 and i have no idea how to add this.
I tried to modify the lisp myself and was half successful. It shows the correct amount of columns but shows no txt in cells 😞 looks blank
PolyInfo.lsp:
;;---------------------=={ Polyline Information }==---------------------;;
;; This program provides the user with detailed information about ;;
;; every segment of a selected polyline in the form of either an ;;
;; AutoCAD Table (if available), Text file, or CSV file. ;;
;; Upon calling the program with the command syntax 'polyinfo' at the ;;
;; AutoCAD command-line, the user is prompted to select an LWPolyline ;;
;; to be queried from the active drawing. At this prompt the user ;;
;; also has the option to choose the form of output for the ;;
;; information harvested by the program; this output format will be ;;
;; remembered between drawing sessions to enable streamlined repeated ;;
;; program usage. ;;
;; The program will output LWPolyline segment data to either an ;;
;; AutoCAD Table Object created in the active drawing (if such object ;;
;; is available in the version of AutoCAD in which the program is ;;
;; being executed), or a tab-delimited Text file or CSV file ;;
;; automatically created (streamlining the program to minimise ;;
;; prompts) in the working directory of the active drawing. ;;
;; For every segment of the selected LWPolyline, the program will ;;
;; extract the following information: ;;
;; • Segment Number ;;
;; • Segment Start Vertex Coordinate ;;
;; • Segment End Vertex Coordinate ;;
;; • Segment Start Width ;;
;; • Segment End Width ;;
;; • Segment Length ;;
;; • Arc Centre (if arc segment) ;;
;; • Arc Radius (if arc segment) ;;
;; Author: Lee Mac, Copyright © 2014 - www.lee-mac.com ;;
;; Version 1.0 - 2012-07-10 ;;
;; - First release. ;;
;; Version 1.1 - 2012-07-16 ;;
;; - Added Table & Text file output options. ;;
;; - Removed basic LWPolyline properties. ;;
;; Version 1.2 - 2014-06-14 ;;
;; - Fixed bug causing final segment to be omitted from output data ;;
;; when processing closed polylines. ;;
;; Version 1.3 - 2015-04-13 ;;
;; - Fixed bug causing the program to crash when processing polylines ;;
;; containing arc segments. ;;
(defun c:polyinfo ( / *error* ent enx flg ins lst out seg tmp )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (= 'str (type out)) (setenv "LMac\\PolyInfo" out))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(if (null (setq out (getenv "LMac\\PolyInfo")))
(setq out "TXT")
(princ
(strcat "\nOutput Format: "
(cond
( (= out "TXT") "Text File")
( (= out "CSV") "CSV File")
( "AutoCAD Table" )
(while
(progn
(setvar 'errno 0)
(initget "Output")
(setq ent (entsel "\nSelect polyline [Output]: "))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (null ent)
nil
( (= "Output" ent)
(polyinfo:chooseoutput 'out)
(princ
(cond
( "AutoCAD Table" )
( (/= "LWPOLYLINE" (cdr (assoc 0 (entget (setq ent (car ent))))))
(princ "\nSelected object is not an LWPolyline.")
(cond
( (and
(= 'ename (type ent))
(= "Table" out)
(= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
(princ "\nCurrent layer locked.")
( (= 'ename (type ent))
(setq seg 0
enx (entget ent)
lst (LM:lwvertices enx)
lst
(cons
(append '("SEG." "START X" "START Y" "END X" "END Y" "WIDTH 1" "WIDTH 2" "LENGTH")
(if (setq flg (vl-some '(lambda ( x ) (not (zerop (cdr (assoc 42 x))))) lst))
'("CENTRE X" "CENTRE Y" "RADIUS")
(mapcar
(function
(lambda ( l1 l2 / b p q )
(setq p (cdr (assoc 10 l1))
q (cdr (assoc 10 l2))
b (cdr (assoc 42 l1))
(append
(list (itoa (setq seg (1+ seg))))
(mapcar 'rtos p)
(mapcar 'rtos q)
(list
(rtos (cdr (assoc 40 l1)))
(rtos (cdr (assoc 41 l1)))
(if (zerop b)
(cons (rtos (distance p q)) (if flg '("" "" "")))
(append
(list (rtos (abs (* (LM:bulgeradius p q b) (atan b) 4))))
(mapcar 'rtos (LM:bulgecentre p q b))
(list (rtos (LM:bulgeradius p q b)))
lst
(if (= 1 (logand 1 (cdr (assoc 70 enx))))
(append (cdr lst) (list (car lst)))
(cdr lst)
(cond
( (= out "TXT")
(if (LM:writetxt lst (setq tmp (vl-filename-mktemp (cdr (assoc 5 enx)) (getvar 'dwgprefix) ".txt")))
(startapp "explorer" tmp)
( (= out "CSV")
(if (LM:writecsv lst (setq tmp (vl-filename-mktemp (cdr (assoc 5 enx)) (getvar 'dwgprefix) ".csv")))
( (setq ins (getpoint "\nSpecify point for table: "))
(LM:startundo (LM:acdoc))
(LM:addtable (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) (trans ins 1 0) nil lst nil)
(princ)
;; Add Table - Lee Mac
;; Generates a table at the given point, populated with the given data and optional title.
;; spc - [vla] VLA Block object
;; ins - [lst] WCS insertion point for table
;; ttl - [str] [Optional] Table title
;; lst - [lst] Matrix list of table cell data
;; eqc - [bol] If T, columns are of equal width
;; Returns: [vla] VLA Table Object
(defun LM:addtable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid )
(setq sty
(vlax-ename->vla-object
(cdr
(assoc -1
(dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle")))
(getvar 'ctablestyle)
(setq hgt (vla-gettextheight sty acdatarow))
(if (LM:annotative-p (setq stn (vla-gettextstyle sty acdatarow)))
(setq hgt (/ hgt (cond ((getvar 'cannoscalevalue)) (1.0))))
(setq wid
(mapcar
'(lambda ( col )
(apply 'max
(mapcar
'(lambda ( str )
( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0))
(textbox
(list
(cons 01 str)
(cons 40 hgt)
(cons 07 stn)
col
(apply 'mapcar (cons 'list lst))
(if
(and ttl
(< 0.0
(setq dif
(textbox
(list
(cons 01 ttl)
(cons 40 hgt)
(cons 07 stn)
(apply '+ wid)
(length wid)
(setq wid (mapcar '(lambda ( x ) (+ x dif)) wid))
(setq obj
(vla-addtable spc
(vlax-3D-point ins)
(1+ (length lst))
(length (car lst))
(* 2.0 hgt)
(if eqc
(apply 'max wid)
(/ (apply '+ wid) (float (length (car lst))))
(vla-put-regeneratetablesuppressed obj :vlax-true)
(vla-put-stylename obj (getvar 'ctablestyle))
(setq i -1)
(if (null eqc)
(foreach col wid
(vla-setcolumnwidth obj (setq i (1+ i)) col)
(if ttl
(progn
(vla-settext obj 0 0 ttl)
(setq i 1)
(progn
(vla-deleterows obj 0 1)
(setq i 0)
(foreach row lst
(setq j 0)
(foreach val row
(vla-settext obj i j val)
(setq j (1+ j))
(setq i (1+ i))
(vla-put-regeneratetablesuppressed obj :vlax-false)
obj
;; Write CSV - Lee Mac
;; Writes a matrix list of cell values to a CSV file.
;; lst - [lst] list of lists, sublist is row of cell values
;; csv - [str] filename of CSV file to write
;; Returns T if successful, else nil
(defun LM:writecsv ( lst csv / des sep )
(if (setq des (open csv "w"))
(progn
(setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
(foreach row lst (write-line (LM:lst->csv row sep) des))
(close des)
t
;; List -> CSV - Lee Mac
;; Concatenates a row of cell values to be written to a CSV file.
;; lst - [lst] list containing row of CSV cell values
;; sep - [str] CSV separator token
(defun LM:lst->csv ( lst sep )
(if (cdr lst)
(strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
(cond
( (wcmatch str (strcat "*[`" sep "\"]*"))
(setq pos 0)
(while (setq pos (vl-string-position 34 str pos))
(setq str (vl-string-subst "\"\"" "\"" str pos)
pos (+ pos 2)
(strcat "\"" str "\"")
( str )
;; Write Text File - Lee Mac
;; Writes a matrix of values to a tab-delimited Text file.
;; lst - [lst] list of lists, sublist is line of text values
;; txt - [str] filename of Text file to write
(defun LM:writetxt ( lst txt / des )
(if (setq des (open txt "w"))
(progn
(foreach itm lst (write-line (LM:lst->str itm "\t") des))
(close des)
t
;; List to String - Lee Mac
;; Concatenates each string in a supplied list, separated by a given delimiter
;; lst - [lst] List of strings to concatenate
;; del - [str] Delimiter string to separate each item
(defun LM:lst->str ( lst del )
(if (cdr lst)
(strcat (car lst) del (LM:lst->str (cdr lst) del))
(car lst)
;; Annotative-p - Lee Mac
;; Predicate function to determine whether a Text Style is annotative.
;; sty - [str] Name of Text Style
(defun LM:annotative-p ( sty )
(and (setq sty (tblobjname "style" sty))
(setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative")))))
(= 1 (cdr (assoc 1070 (reverse sty))))
;; LW Vertices - Lee Mac
;; Returns a list of lists in which each sublist describes
;; the position, starting width, ending width and bulge of the
;; vertex of a supplied LWPolyline
(defun LM:lwvertices ( e )
(if (setq e (member (assoc 10 e) e))
(cons
(list
(assoc 10 e)
(assoc 40 e)
(assoc 41 e)
(assoc 42 e)
(LM:lwvertices (cdr e))
;; Bulge Radius - Lee Mac
;; p1 - start vertex
;; p2 - end vertex
;; b - bulge
;; Returns the radius of the arc described by the given bulge and vertices
(defun LM:bulgeradius ( p1 p2 b )
(/ (* (distance p1 p2) (1+ (* b b))) 4 (abs b))
;; Bulge Centre - Lee Mac
;; p2 - end vertex
;; b - bulge
;; Returns the centre of the arc described by the given bulge and vertices
(defun LM:bulgecentre ( p1 p2 b )
(polar p1
(+ (angle p1 p2) (- (/ pi 2) (* 2 (atan b))))
(/ (* (distance p1 p2) (1+ (* b b))) 4 b)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(vl-load-com)
(eval
(append
(list 'defun 'polyinfo:chooseoutput '( sym ))
(if (vlax-method-applicable-p (vla-get-modelspace (LM:acdoc)) 'addtable)
(list
'(initget "Table TXT CSV")
'(set sym (cond ((getkword (strcat "\nChoose Output [Table/TXT/CSV] <" (eval sym) ">: "))) ((eval sym))))
(list
'(initget "TXT CSV")
'(set sym (cond ((getkword (strcat "\nChoose Output [TXT/CSV] <" (eval sym) ">: "))) ((eval sym))))
(princ
(strcat
"\n:: PolyInfo.lsp | Version 1.3 | \\U+00A9 Lee Mac "
(menucmd "m=$(edtime,0,yyyy)")
" www.lee-mac.com ::"
"\n:: Type \"polyinfo\" to Invoke ::"
(princ)
;; End of File ;;
john.uhden
Maybe, if I remember tomorrow, I can donate my SEGLIST,lsp which reports basically everything about a line, arc, or polyline segment, even if nested in a block or Xref.  It just prints to the textscreen, no fancy tables or dialogs.  It is intended for units of feet and DMS, so I think it uses a maximum of LUPREC or 2 and AUPREC or 4.  I am a civil type.  May God bless you if you are not.
John F. Uhden
dbhunia
Check the attached LISP.......(Modified)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
john.uhden
I'm sorry.  My SEGLIST function uses too many functions that are in my base file (conversion, formatting), so I don't feel like digging them out and incorporating them into the content of the single LSP file.  Most of the code I use is assembled together in one VLX.   Also, I'm a little embarassed because it doesn't use any vlax-curve functions; it's all the old fashioned way.  You have a good solution anyway.
John F. Uhden
That works perfectly!
Thank you sir!
