Help each time I start AutoCAD I get s::startup-load
pewpewx
pewpewx
I just don't remember how it happened. I created a new lsp file from some code I pasted off of a website. Saved it in a notepad as a .lsp file and ran APPLOAD. After that things started going crazy. Now, each time I start AutoCAD I get s::startup-load. I am not sure if both of these things are even related but I need to just use autocad without this prompt crashing the application. i attached the lisp that make this thing started
Moshe-A
@pewpewx  hi,
if you add some lisp file(s) to appload or add code to acad.lsp first remove them to see if this solves the problem
Moshe
