How to Autolisp calculate area ratio of two groups?
raymondcheng0922
Message 1 of 13
raymondcheng0922
Replies (12)
Message 2 of 13
raymondcheng0922
(defun C:area-ratio ( / ent1 ent2 area1 area2 total)
  (setq ent1 (entsel "
Select the first group of objects: "))
  (setq area1 (vl-cmdf "_.area" ent1))
  (setq ent2 (entsel "
Select the second group of objects: "))
  (setq area2 0)
  (foreach ent ent2
    (setq area2 (+ area2 (vl-cmdf "_.area" ent)))
  (setq total (+ area1 area2))
  (setq first-ratio (* 100.0 (/ area1 total)))
  (setq second-ratio (* 100.0 (/ area2 total)))
  (setq pt (getpoint "
Specify the insertion point for the output: "))
  (setq output (strcat "The area of the first group is " (rtos first-ratio 2) "% of the total area."))
  (setq output (strcat output (strcat "\nThe area of the second group is " (rtos second-ratio 2) "% of the total area.")))
  (entmake (list (cons 0 "TEXT") (cons 10 pt) (cons 1 output)))
Message 3 of 13
pbejse
Are you referring to AutoCAD  GROUP selection type or group of objects ? ( Polylines/Circles/Hatch...) ?
Message 4 of 13
raymondcheng0922
Two sets of polygons total area
Message 5 of 13
raymondcheng0922
Exsamlpe
What is the percentage of one of the 8 unit buildings?
Message 6 of 13
pbejse
(defun C:area-ratio (/ _sel firstGroup area1 area2 secondGroup total first-ratio second-ratio pt output )
  (defun _sel (ss / ent i totalArea)
    (setq totalArea 0)
    (repeat (setq i (sslength ss))
      (setq ent (ssname ss (setq i (1- i))))
      (setq totalArea (+ totalArea (getpropertyvalue ent "Area")))
    totalArea
  (if (and
	(princ "\nFirst group of objects: ")
	(setq firstGroup (ssget '((0 . "LWPOLYLINE"))))
	(princ "\nSecond group of objects: ")
	(setq secondGroup (ssget '((0 . "LWPOLYLINE"))))
	(setq pt (getpoint "\nSpecify the insertion point for the output: "))
    (progn
      (setq area1 (_sel firstGroup))
      (setq area2 (_sel secondGroup))
      (entmakex	(list (cons 0 "MTEXT")
		      (cons 100 "AcDbEntity")
		      (cons 100 "AcDbMText")
		      (cons 10 pt)
		      (cons 1 output)
	(princ (Strcat "\n" output))
  (princ)
Command: AREA-RATIO
Select objects: Specify opposite corner: 2 found
Select objects: < presss enter/spacebar >
The area of the first group is 58.0943% of the total area.
The area of the second group is 41.9057% of the total area.
HTH
Message 7 of 13
raymondcheng0922
Just ask, can it be combined with the attached LSP
Message 8 of 13
pbejse
I guess we can do that. how you would want the result to look? The highlighted as field value?
Message 9 of 13
raymondcheng0922
Like you think 。thank you
Message 10 of 13
raymondcheng0922
Thanks for the demo, it works elsewhere, very useful
Message 11 of 13
pbejse
Are you responding to my post or some other random help you got from  someplace/someone  else?
Message 12 of 13
raymondcheng0922
Just replying for your help, but no one else has a solution
Message 13 of 13
raymondcheng0922
In fact, can my own lsp calculate part of it, and use other lsp? Calculate part call LengthAreaField V1-4.lsp?
