DGN import settings through variable or registry key
Michiel.Valcke
Advisor Advisor
Message 1 of 1
Michiel.Valcke
Hello everyone,
For a project I'm in the process of creating a routine that among other things, does a batch conversion from DGN files to DWG.
While doing the conversion there are several settings that might need to be switched depending on the name/location of the DGN files. These settings are those encountered when using the DGNIMPORT command.
I have found how to set most of these settings (either through the DGNIMPORTMODE system variable or during a call to the -DGNIMPORT command)
But for two settings in particular I have not found a corresponding system variable or registry key that I can change with the lisp routine.
Does anybody know how I can set the External DGN references and the explode text nodes settings with lisp?
Replies (0)
