Hatchedit only changes one
C.Utzinger
Message 1 of 34
C.Utzinger
 HI
I have the following code, but the Problem is it works only for one hatch. If I select more than one, then only the last selected one changes.
What can I do?
(defun c:<Test5 ( / *error* layr cmd SPIhatch)
	(defun *error* (errmsg)
    	   (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      	   (princ (strcat "\nError: " errmsg)))
    	   (setvar 'CLAYER layr)
    	   (setvar 'CMDECHO cmd)
	   (command-s "_.undo" "_end")
    	   (princ "\n"))
     	(setq layr (getvar 'CLAYER)
              cmd (getvar 'CMDECHO))
	(setq SPIhatch (ssget "I"))
	(if (not SPIhatch)
		 (progn
		   (command "_.undo" "_begin")
		   (setvar 'CMDECHO 0)
  		   (command "_.-LAYER" "_m" "-I-Schraffur" "_co" "8" "-I-Schraffur" "")
		   (setvar 'HPNAME "NET")
		   (command "_.-bhatch" "_l" "-I-Schraffur" "_p" "NET" "2" "0" "_a" "_h" "_y" "_a" "_y" "" "_co" "bylayer" "_n" "")
		   (setvar 'CMDECHO 1)
		   (command "_.-bhatch")
		   (while (> (getvar "cmdactive") 0) (command pause))
		   (setvar 'CLAYER lay)
		   (command "_.undo" "_end")
		   (prin1))
		 (progn
		   (command "_.-hatchedit" SPIhatch "_p" "NET" "2" "0")
		   (command "_.-hatchedit" SPIhatch "LA" "-I-Schraffur")
		   (prompt "\nSchraffur angepasst und auf Layer -I-Schraffur gewechselt!")
  		   (princ))
) ;_ end of defun
Replies (33)
Message 2 of 34
hencoop
Put the commands in a WHILE loop for the length of the selection set.
    	   (princ "\n"))
	(if (not SPIhatch)
		 (progn
		   (setvar 'CMDECHO 0)
		   (setvar 'CMDECHO 1)
		   (prin1))
		 (progn
                   (SETQ cnt 0)
                   (WHILE (< cnt (SSLENGTH SPIhatch))
		     (command "_.-hatchedit" (SSNAME SPIhatch cnt) "" "_p" "NET" "2" "0")
		     (command "_.-hatchedit" (SSNAME SPIhatch cnt) "" "LA" "-I-Schraffur")
                     (SETQ cnt (1+ cnt))
  		   (princ))
) ;_ end of defun
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Message 3 of 34
C.Utzinger
Sorry but does not work!
Message 4 of 34
hencoop
what does it do?
Message 5 of 34
C.Utzinger
Just the same. Only the last hatch of the selection gets changed.
Message 6 of 34
hencoop
I'm sorry, bonehead blunder on my part.
I forgot to replace SPIhatch with (SSNAME SPIhatch cnt) ""
I updated my code post... try it now.
Message 7 of 34
C.Utzinger
Sorry but it doesn't work!
Now ist difficult to explain was it does Smiley LOL
Only one changes the pattern, but not the layer. And then the Routine stops saying that the pattern is incorrect. Really strange!
Thank you by the way...
Message 8 of 34
C.Utzinger
Now it works
Take away the "" after (SSNAME SPIhatch cnt)!!!
Message 9 of 34
hencoop
I think the remaining problem is in the command sequence.
step through the command at the command line taking note of each input required.
When you are asked to select the hatch that is where (SSNAME SPIhatch cnt) belongs in your code.
there needs to be a termination of the selection which is "" right after (SSNAME SPIhatch cnt) in the code.
Carefully replicate the required input in your code until you are returned to the command prompt for each command sequence.
I think that will fix it.
Message 10 of 34
C.Utzinger
This way it works perfect
Post the complete code and I accept it as solution.
		     (command "_.-hatchedit" (SSNAME SPIhatch cnt) "_p" "NET" "2" "0")
		     (command "_.-hatchedit" (SSNAME SPIhatch cnt) "LA" "-I-Schraffur")
Message 11 of 34
hencoop
Good catch!  I use a different setting for the PICK variables than you use.
Message 12 of 34
hencoop
As you requested:
    	   (princ "\n"))
	(if (not SPIhatch)
		 (progn
		   (setvar 'CMDECHO 0)
		   (setvar 'CMDECHO 1)
		   (prin1))
		 (progn
                   (SETQ cnt 0)
                     (SETQ cnt (1+ cnt))
  		   (princ))
) ;_ end of defun
Message 13 of 34
C.Utzinger
Which Pick variable?
I will try, and perhaps fix the correct one in the Routine!
Thank you very much!
Message 14 of 34
hencoop
There is not a "correct" setting.  It is a user preference.  The different settings can change the required command line input when making selections.  All that is necessary is to make the command line input match the current selection sequence.  To make the routine work regardless of the settings you would capture the value of the pick variables that are involved (I would not know which are without experimenting with them) and set them to values that work for your command sequence and then reset them at the end of the program.
My current settings are (COMMAND "SETVAR" "?" "PICK*"):
PICKADD 2
PICKAUTO 5
PICKBOX 5
PICKDRAG 2
PICKFIRST 1
PICKSTYLE 1
Message 15 of 34
C.Utzinger
I have another Problem with the code.
It crashes when you have selected some hatches and an other object (line).
I tryed to fix this, but it only works if I only select one object (line):
(if (ssget "I" '((0 . "HATCH")))(setq SPIhatch (ssget "I"))(alert "Keine Schraffur gewählt"))
Can you help me?
Message 16 of 34
hencoop
It appears that you do not need to select anything but hatches.  Is that correct?
If so, I can tailor the SSGET function to only allow selection of hatch objects to solve the problem.
Message 17 of 34
C.Utzinger
Yes i need only to get hatches...
Thank in advance
Message 18 of 34
hencoop
change this line
make it this
(setq SPIhatch (ssget "I" '((0 . "HATCH"))))
 Or, this is you want it to prompt you to select them
(setq SPIhatch (ssget '((0 . "HATCH"))))
I've got to run.  I'll pick it up tomorrow if you still need some fixing
Message 19 of 34
C.Utzinger
HI
No, I want to Change them directly without prompt.
So with your second code it work fine without braking the Routine:
Now it would be great if there comes some alert saying that there were other objects than hatches...
Can you fix this??? I tried some, but nothing worked...
Message 20 of 34
hencoop
with this SSGET code:
your selection is filtered to only select the hatches.  It cannot select anything else.
