Hatchedit only changes one
C.Utzinger
Message 1 of 34
C.Utzinger
 HI
I have the following code, but the Problem is it works only for one hatch. If I select more than one, then only the last selected one changes.
What can I do?
(defun c:<Test5 ( / *error* layr cmd SPIhatch)
	(defun *error* (errmsg)
    	   (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      	   (princ (strcat "\nError: " errmsg)))
    	   (setvar 'CLAYER layr)
    	   (setvar 'CMDECHO cmd)
	   (command-s "_.undo" "_end")
    	   (princ "\n"))
     	(setq layr (getvar 'CLAYER)
              cmd (getvar 'CMDECHO))
	(setq SPIhatch (ssget "I"))
	(if (not SPIhatch)
		 (progn
		   (command "_.undo" "_begin")
		   (setvar 'CMDECHO 0)
  		   (command "_.-LAYER" "_m" "-I-Schraffur" "_co" "8" "-I-Schraffur" "")
		   (setvar 'HPNAME "NET")
		   (command "_.-bhatch" "_l" "-I-Schraffur" "_p" "NET" "2" "0" "_a" "_h" "_y" "_a" "_y" "" "_co" "bylayer" "_n" "")
		   (setvar 'CMDECHO 1)
		   (command "_.-bhatch")
		   (while (> (getvar "cmdactive") 0) (command pause))
		   (setvar 'CLAYER lay)
		   (command "_.undo" "_end")
		   (prin1))
		 (progn
		   (command "_.-hatchedit" SPIhatch "_p" "NET" "2" "0")
		   (command "_.-hatchedit" SPIhatch "LA" "-I-Schraffur")
		   (prompt "\nSchraffur angepasst und auf Layer -I-Schraffur gewechselt!")
  		   (princ))
) ;_ end of defun
Replies (33)
Message 21 of 34
C.Utzinger
I have it! Perhaps there is an easier way, but this one works!:
  (setq SPIhatch (ssget "I" '((0 . "HATCH"))))
  (setq SPIhatch2 (ssget "I"))
  (if (not (= (SSLENGTH SPIhatch2) (SSLENGTH SPIhatch)))
      (progn
        (alert "Nur Schraffuren wählen! \nNochmals versuchen :P")
        (exit)))
Message 22 of 34
C.Utzinger
Now I have got the final version!!!
(defun c:<Test3 ( / *error* lay cmd logname SPIhatch SPIhatch2 cnt)
	(sssetfirst nil SPIhatch)
    	(princ "\n"))
  (setq lay (getvar 'CLAYER)
  (setq logname (getvar "loginname"))
  (if (and SPIhatch2 (not SPIhatch))
          (progn
	  (alert (strcat "Keine Schraffur gewählt! \n\nSali " logname "! Darfst es nochmals versuchen :D..."))
          (exit)))
  (if (and SPIhatch SPIhatch2 (not (= (SSLENGTH SPIhatch2) (SSLENGTH SPIhatch))))
          (progn
	  (alert (strcat "Nur Schraffuren wählen! \n\nSali " logname "! Darfst es nochmals versuchen :D..."))
          (exit)))
  (if (not SPIhatch)
      (progn
        (setvar 'CMDECHO 0)
  	(command "_.-LAYER" "_m" "-I-Schraffur-Beton-Schnitt-grau" "_co" "253" "-I-Schraffur-Beton-Schnitt-grau" "")
	(setvar 'HPNAME "SOLID")
	(command "_.-bhatch" "_l" "-I-Schraffur-Beton-Schnitt-grau" "_a" "_h" "_y" "_a" "_y" "" "_co" "bylayer" "")
	(setvar 'CMDECHO 1)
	(prin1))
      (progn
        (SETQ cnt 0)
        (WHILE (< cnt (SSLENGTH SPIhatch))
          (command "_.-hatchedit" (SSNAME SPIhatch cnt) "_p" "SOLID")
          (command "_.-hatchedit" (SSNAME SPIhatch cnt) "_l" "-I-Schraffur-Beton-Schnitt-grau")
          (SETQ cnt (1+ cnt)))
        (prompt "\nSchraffur angepasst und auf Layer -I-Schraffur-Beton-Schnitt-grau gewechselt!")
        (princ))
) ;_ end of defun
Thank you!!!!
Message 23 of 34
ВeekeeCZ
Time to learn the (cond) finction !!
And some more... untested.
(vl-load-com)
(defun c:<Test3 ( / *error* adoc lay cmd logname SPIhatch SPIno-hatch i)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
    (vla-endundomark adoc)
    (princ "\n")
    (princ))
	logname (getvar 'LOGINNAME))
  (vla-endundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (vla-startundomark adoc)
	SPIno-hatch (ssget "I"))
  (cond ((and SPIno-hatch
	      (not SPIhatch))
	 (alert (strcat "Keine Schraffur gewählt! \n\nSali " logname "! Darfst es nochmals versuchen :D...")))
	((and SPIhatch
	      SPIno-hatch
	      (/= (sslength SPIno-hatch)
		  (sslength SPIhatch)))
	 (alert (strcat "Nur Schraffuren wählen! \n\nSali " logname "! Darfst es nochmals versuchen :D...")))
	((not SPIhatch)
	 (setvar 'CMDECHO 0)
	 (setvar 'CMDECHO 1)
	 (while (> (getvar 'CMDACTIVE) 0) (command pause)))
	(T
	 (repeat (setq i (sslength SPIhatch))
	   (command "_.-hatchedit" (ssname SPIhatch (setq i (1- i))) "_p" "SOLID"
		    "_.-hatchedit" (ssname SPIhatch i) "_l" "-I-Schraffur-Beton-Schnitt-grau"))
	 (prompt "\nSchraffur angepasst und auf Layer -I-Schraffur-Beton-Schnitt-grau gewechselt!")))
  (*error* "end")
 Gute Nacht! Sorry for digging into "final" - there should be a lock button to prevent from those guys!
Message 24 of 34
C.Utzinger
You my Hero!!!!
I tried something with COND, but only crab was coming out...Smiley LOL
There is only one problem i think. The code crashes if you only select one hatch, it breaks in the hatchedit command.
Thank you in advance...
Message 25 of 34
ВeekeeCZ
Would you post a test dwg?
Message 26 of 34
C.Utzinger
Of course...
Message 27 of 34
ВeekeeCZ
I don't understand why is that so complicated.
What's the purpose of this line?
my reading is if the was pre-selected some hathes AND some hathes with something else (lwpolylines?) AND the both groups does not have the same mount of members.
Why not just adjust HATCHes if there were pre-selected, othewise let the user make new one. Not care about polylines...
Message 28 of 34
C.Utzinger
OK, it's just when you select the hatches one by one and per accident get another object than a hatch.
If you have 20 hatches and you got selected 18 and per accident 2 other objects, and the 18 changes and the other 2 not, perhaps you don't notice that...
It is just to advice that you have selected an other object.
But this is not the Problem i think, because that is working fine. It's just when you select only one hatch for change, then comes the hachtedit menue and the Routine crashes.
Sorry about my english!
Message 29 of 34
ВeekeeCZ
You should filter them out automatically and not bother the users.
I really like the Tool Palettes for HATCHinch, see how it works... HERE - it's very easy to set layer, color, hatch pattern, all returns back after the usage.
Message 30 of 34
C.Utzinger
Thank you.
I know them, but we are getting away from them and just want to work with Ribbons.
Message 31 of 34
ВeekeeCZ
Hmm... bad for you.
Well, here is my version. Really don't like your alerts.
(vl-load-com)
(defun c:<Test3 ( / *error* oVAR nVAR adoc ss)
    (mapcar 'setvar nVAR oVAR)
    (princ))
  (setq oVAR (mapcar 'getvar (setq nVAR '(CMDECHO CLAYER HPNAME HPLAYER))))
  (setq ss (ssget "_I" '((0 . "HATCH"))))
  (setvar 'CMDECHO 0)
  (setvar 'HPLAYER ".")
  (command "_.-LAYER" "_M" "-I-Schraffur-Beton-Schnitt-grau"
           "_CO" "253" "-I-Schraffur-Beton-Schnitt-grau"
           "_T" "-I-Schraffur-Beton-Schnitt-grau"
           "_S" "-I-Schraffur-Beton-Schnitt-grau"
  (if ss
    (progn
      (initcommandversion)
      (command "_.-HATCHEDIT" ss "" "_P" "Solid")
      (command "_.-HATCHEDIT" ss "" "_Layer" "-I-Schraffur-Beton-Schnitt-grau")
    (progn
      (command "_.-BHATCH" "_a" "_h" "_y" "_a" "_y" "" "_co" "bylayer" "")
      (setvar 'CMDECHO 1)
      (command "_.-BHATCH")
      (while (> (getvar 'CMDACTIVE) 0) (command PAUSE))))
  (*error* "end")
Message 32 of 34
ВeekeeCZ
Ok, one thing still bothers me... the routine fails if all selected objects are on locked layer. There is no easy way to do that using the (ssget)'s filters - the combination with Implied selection is the issue. What we can do is prevent the (command) from the failing using (command-s) instead (blue ones)..., but your following prompt will show not matter if the hatchedit was success or failed.
So I made the sub-function which exclude objects on lock layers from the given selection.
(vl-load-com)
(defun c:<Test3 ( / *error* oVAR nVAR adoc :sslockless ss)
    (princ))
  (defun :sslockless (ss / i en)
    (repeat (setq i (sslength ss))
      (if (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 (entget (setq en (ssname ss (setq i (1- i))))))))))))
        (ssdel en ss)))
    (if (and ss (< 0 (sslength ss))) ss nil))
  (setq ss (ssget "I" '((0 . "HATCH"))))
  (setvar 'CMDECHO 0)
  (cond ((and ss
              (not (setq ss (:sslockless ss)))
         (sssetfirst nil nil)
         (alert "All selected objects were on locked layers."))
        (ss
        (T
         (setvar 'CMDECHO 1)
  (*error* "end")
Message 33 of 34
C.Utzinger
WOW thank you...
I will look at it on monday, i have to leave now.
Nice Weekend...
Message 34 of 34
C.Utzinger
Wow!
Thank you very much.
I also editet my prompt, with an advice that locked object didn't Change.
Kind regards
