Plot to PDF using a multi-field name ?!?!
maramuresul
maramuresul
Is there a possibility to plot  PDF with a name that is taken from layout fields.
As example, I want my filename.dwg , with layouts 1,2,3,4 be plotted to pdf (each layout separate) with a name like:
   Name - Layout - Rev ## - Description.pdf  ,
 where:
   Name -    can be Drawing number - from layout field  or filename
   Layout - layout name/number
   Rev ## -  Revision number -from layout field ( Revision )
   Description -  contents - from layout ( Drawing title, Project title and so on )
For more information please contact me.
Kind regards,
Andrei
pendean
Community Legend
Community Legend
With lisp or other customizations, yes.
With only using the tools in the program, no.
Customization forums are here, start in the LISP forum, ask for help if you need it https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
