Find Intersection point automatically
Message 1 of 52
I have a lot of line which have to cut a single line. I need to know all intersection point location. How can I find it easily? Can I do it with a single command?
Thanks in advance.
Replies (51)
Message 2 of 52
Patchy
https://www.cadstudio.cz/en/download.asp?file=IntLines
Then use Dataextraction.
How many lines do you have? ☺
Message 3 of 52
Thank you for your reply. I have almost 100 intersection points. I have to find out every intersection points locations.
Message 4 of 52
Patchy
Upload the example, let's see if it can be done ☺
Please upload 2007 version ☺
Message 5 of 52
pendean
Community Legend
Community Legend
How do you think these 100 points should be presented to you? explain your expectations or wishes in more detail, if needed, fake something visual in your file to show us.
Message 6 of 52
Here it is sir.
Message 7 of 52
Yes, I have uploaded a sample drawing file, Kindly see the drawing.
I have to find out the location where red line cuts the white line.
Message 8 of 52
Patchy
You want the coordinates or dimensions?
Message 9 of 52
Sir, the red line midpoint would be (x,y) = (0,0), if I want find out the coordinate. or it would be dimension form the red line mid point.
Message 10 of 52
actually, I need the distance from the red line mid point to intersection point
Message 11 of 52
hak_vz
(defun c:intersections nil(intersections))
(defun intersections ( / e eo ss i getintersections mappend mklist flatten pointlist3d io int all)
(defun getintersections	(obj1 obj2 / var)
     ; from RonJonP
     (setq var (vlax-variant-value (vla-intersectwith obj1 obj2 1)))
     (if (< 0 (vlax-safearray-get-u-bound var 1))
	  (vlax-safearray->list var)
     ) ;_ end of if
) ;_ end of defun
(defun mappend (fn lst) ; Peter Norvig ??
     ; Append the results of calling fn on each element of list.
     ; Like mapcon, but uses append instead of nconc."
     ; One thing to notice is that fn must return a list, otherwise, it will go wrong.
     ; usage: (mappend '(lambda (x) (list x (* x x))) '(1 2 3))
     (apply 'append (mapcar fn lst))
) ;_ end of defun
(defun mklist (x)
     ; If x is a list return it, otherwise return the list of x
     (if (listp x)
	  x
	  (list x)
     ) ;_ end of if
) ;_ end of defun
(defun flatten (expr)
     ; Get rid of imbedded lists (to one level only)."
     (mappend 'mklist expr)
) ;_ end of defun
(defun pointlist3d (lst / ret)
     ; converts one dimensional list (vector) to list of 3d points
     (while lst
	  (setq	ret (cons (list (car lst) (cadr lst) (caddr lst)) ret)
		lst (cdddr lst)
	  ) ;_ end of setq
     ) ;_ end of while
     (reverse ret)
) ;_ end of defun
(while (not e )(setq e (car (entsel "\nSelect base object > "))))
(setq eo (vlax-ename->vla-object e))
(princ "\nSelect intersection objects >")
(setq ss (ssget) i 0)
(repeat (sslength ss)
	(setq io (vlax-ename->vla-object (ssname ss i)))
	(setq int (pointlist3d(flatten(getintersections eo io))))
	(if (and int)(setq all (cons int all)))
	(setq i (+ i 1))
all
Try this.
Miljenko Hatlak
Message 12 of 52
Thanks a lot. But I am sorry sir, I don't know how to input this. I know programming, but don't know about autocad coding. Please help me sir
Message 13 of 52
Patchy
Maybe like this.
Message 14 of 52
WOW! How you do it? 😄
Message 15 of 52
Patchy
Most of the autolisp I used were from here:
http://www.lee-mac.com/index.html
Message 16 of 52
OK sir. Thank you. But could you please tell me how you do that? How you find out all coordinate points?
Message 17 of 52
hak_vz
Save this code to a file with extension .lsp  i.e.  intersections.lsp. Load it into AUTOCAD though menus
tools-> load application -> select wile name
or by using command APPLOAD
When loaded type command INTERSTECTIONS  to console and follow what it asks.
For your sample when origin is set to 0,0 you will receive a list:
Miljenko Hatlak
Message 18 of 52
hak_vz
@Patchyhas something that is probably easier for you to use since you don't know how to use lisp code, and you didn't elaborated how you want  your intersection list to be represented.
Miljenko Hatlak
Message 19 of 52
Sir, I successfully load the app. After that I cannot do what it wants. It is asking for base objects.
Message 20 of 52
Yes sir.  @Patchy sir's solution is enough for my work. I need this type of output. I would like to request @Patchy sir, how he do it?
