Lets start with some code. Here is my code that collects all blocks for a panel and then produce a list of blocks and counts elements of equal length.
(defun c:cutlist nil (cutlist))
(defun cutlist ( / ss i e eo blocknames lens block_list len_list);
(defun LM:unique (lst)(if (and lst) (cons (car lst) (LM:unique (vl-remove (car lst) (cdr lst))))))
(defun LM:getdynpropvalue ( blk prp )
(setq prp (strcase prp))
(vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
(vlax-invoke blk 'getdynamicblockproperties)
(princ "\nSelect a panel inside closing window >")
(setq ss (ssget '((0 . "insert") (8 . "C16 TIMBER"))))
(setq i 0)
(repeat (sslength ss)
(setq e (ssname ss i) eo (vlax-ename->vla-object e))
(if (vlax-property-available-p eo 'effectivename)
(setq blocknames (cons (vlax-get eo 'effectivename) blocknames))
(setq i (+ i 1))
(setq blocknames (LM:unique blocknames) len_list (list) block_list (list))
(foreach block blocknames
(setq i 0 lengthlist nil)
(if (= (vlax-get eo 'effectivename) block)
(setq lengthlist (cons (lM:getdynpropvalue eo "Distance1") lengthlist))
(setq i (+ i 1))
(setq lens (LM:unique lengthlist) i 0 cnt 0)
(foreach len lens
(repeat (length lengthlist)
(if (= len (nth i lengthlist)) (setq cnt (+ cnt 1)))
(setq i (+ i 1))
(setq len_list (append len_list (list(list len cnt))))
(setq i 0 cnt 0 )
(setq block_list (append block_list (list(list block len_list))) len_list (list) )
block_list
When run on your sample it produces following list in a format
Block name - list of unique length for that block and its number
("1. Timber - Blue Interlocking Flexible Length" ((2275.0 2) (4540.84 1)))
("1. Timber - Flexible Length" ((4360.84 5) (2275.0 3) (92.5 3) (555.0 6)
(487.5 3)))
("1. Timber - 245 Cripple Stud Flexible" ((4360.84 8))))
This can be converted to a table. Procedure requires precise drafting as well.
Miljenko Hatlak
