Find Intersection point automatically
Message 1 of 52
I have a lot of line which have to cut a single line. I need to know all intersection point location. How can I find it easily? Can I do it with a single command?
Thanks in advance.
Replies (51)
Message 21 of 52
hak_vz
@Anonymous wrote:
Sir, I successfully load the app. After that I cannot do what it wants. It is asking for base objects.
base object -> select rectangle or a line
intersection objects -> all red lines
You will receive a list
(((-18.4165 7.10543e-15 0.0) (18.4165 7.10543e-15 0.0)) ((-18.4165 -2.32654 0.0) (18.4165 2.32654 0.0)) ((-18.4165 -4.72855 0.0) (18.4165 4.72855 0.0)) ((-18.4165 -7.29161 0.0) (18.4165 7.29161 0.0)) ((-18.4165 -10.1246 0.0) (18.4165 10.1246 0.0)) ((-18.4165 -13.3804 0.0) (18.4165 13.3804 0.0)) ((18.4165 17.2942 0.0) (-14.2687 -13.3992 0.0)) ((14.9473 18.0682 0.0) (-11.0848 -13.3992 0.0)) ((11.4665 18.0682 0.0) (-8.5034 -13.3992 0.0)) ((8.50227 18.0682 0.0) (-6.30519 -13.3992 0.0)) ((5.87073 18.0682 0.0) (-4.35367 -13.3992 0.0)) ((3.4467 18.0682 0.0) (-2.55604 -13.3992 0.0)) ((1.13676 18.0682 0.0) (-0.843007 -13.3992 0.0)) ((-1.13676 18.0682 0.0) (0.843007 -13.3992 0.0)) ((-3.4467 18.0682 0.0) (2.55604 -13.3992 0.0)) ((-5.87073 18.0682 0.0) (4.35367 -13.3992 0.0)) ((-8.50227 18.0682 0.0) (6.30519 -13.3992 0.0)) ((-11.4665 18.0682 0.0) (8.5034 -13.3992 0.0)) ((-14.9473 18.0682 0.0) (11.0848 -13.3992 0.0)) ((-18.4165 17.2942 0.0) (14.2687 -13.3992 0.0)) ((-18.4165 13.3804 0.0) (18.4165 -13.3804 0.0)) ((-18.4165 10.1246 0.0) (18.4165 -10.1246 0.0)) ((-18.4165 7.29161 0.0) (18.4165 -7.29161 0.0)) ((-18.4165 4.72855 0.0) (18.4165 -4.72855 0.0)) ((-18.4165 2.32654 0.0) (18.4165 -2.32654 0.0)) ((-18.4165 -1.77636e-14 0.0) (18.4165 2.84217e-14 0.0)) ((-18.4165 -2.32654 0.0) (18.4165 2.32654 0.0)) ((-18.4165 -4.72855 0.0) (18.4165 4.72855 0.0)) ((-18.4165 -7.29161 0.0) (18.4165 7.29161 0.0)) ((-18.4165 -10.1246 0.0) (18.4165 10.1246 0.0)) ((-18.4165 -13.3804 0.0) (18.4165 13.3804 0.0)) ((18.4165 17.2942 0.0) (-14.2687 -13.3992 0.0)) ((14.9473 18.0682 0.0) (-11.0848 -13.3992 0.0)) ((11.4665 18.0682 0.0) (-8.5034 -13.3992 0.0)) ((8.50227 18.0682 0.0) (-6.30519 -13.3992 0.0)) ((5.87073 18.0682 0.0) (-4.35367 -13.3992 0.0)) ((3.4467 18.0682 0.0) (-2.55604 -13.3992 0.0)) ((1.13676 18.0682 0.0) (-0.843007 -13.3992 0.0)) ((-1.13676 18.0682 0.0) (0.843007 -13.3992 0.0)) ((-3.4467 18.0682 0.0) (2.55604 -13.3992 0.0)) ((-5.87073 18.0682 0.0) (4.35367 -13.3992 0.0)) ((-8.50227 18.0682 0.0) (6.30519 -13.3992 0.0)) ((-11.4665 18.0682 0.0) (8.5034 -13.3992 0.0)) ((-14.9473 18.0682 0.0) (11.0848 -13.3992 0.0)) ((-18.4165 17.2942 0.0) (14.2687 -13.3992 0.0)) ((-18.4165 13.3804 0.0) (18.4165 -13.3804 0.0)) ((-18.4165 10.1246 0.0) (18.4165 -10.1246 0.0)) ((-18.4165 7.29161 0.0) (18.4165 -7.29161 0.0)) ((-18.4165 4.72855 0.0) (18.4165 -4.72855 0.0)) ((-18.4165 2.32654 0.0) (18.4165 -2.32654 0.0)))
But I don't know how will you use it
Miljenko Hatlak
Message 22 of 52
Patchy
I use the Autodesk Land Desktop (daddy of now civil 3d) to get the coordinates. It's old and not available anymore.
You can use this:
http://www.lee-mac.com/ptmanager.html
http://www.lee-mac.com/midlen.html
and use Dataextraction to get coordinates
Message 23 of 52
Oh, That's great. I have done it. Thanks a lot sir. 😄
For my learning purpose, I would like to request @Patchy sir, please tell me your process elaborately. And your output will be more efficient for me.
Message 24 of 52
Thanks a lot sir. Could you please send me a video of that, it will be more helpful for me. I am requesting you, If you could do that.
Message 25 of 52
hak_vz
You didn't answer a question from @pendean  about how you want intersection points to be presented.
Do you want them extracted to spreadsheet (Excel), create a table inside autocad file, else?
Miljenko Hatlak
Message 26 of 52
I am sorry sir, I want the output as Excel.
Message 27 of 52
hak_vz
Here you have it. It exports intersection points to CSV file that you can open with Excel.
(defun c:intersections nil(intersections))
(defun intersections ( / e eo ss i getintersections mappend mklist flatten pointlist3d io int all);
(defun getintersections	(obj1 obj2 / var)
     ; from RonJonP
     (setq var (vlax-variant-value (vla-intersectwith obj1 obj2 0)))
     (if (< 0 (vlax-safearray-get-u-bound var 1))
	  (vlax-safearray->list var)
     ) ;_ end of if
) ;_ end of defun
(defun mappend (fn lst) ; Peter Norvig ??
     ; Append the results of calling fn on each element of list.
     ; Like mapcon, but uses append instead of nconc."
     ; One thing to notice is that fn must return a list, otherwise, it will go wrong.
     ; usage: (mappend '(lambda (x) (list x (* x x))) '(1 2 3))
     (apply 'append (mapcar fn lst))
) ;_ end of defun
(defun mklist (x)
     ; If x is a list return it, otherwise return the list of x
     (if (listp x)
	  x
	  (list x)
     ) ;_ end of if
) ;_ end of defun
(defun flatten (expr)
     ; Get rid of imbedded lists (to one level only)."
     (mappend 'mklist expr)
) ;_ end of defun
(defun pointlist3d (lst / ret)
     ; converts one dimensional list (vector) to list of 3d points
     (while lst
	  (setq	ret (cons (list (car lst) (cadr lst) (caddr lst)) ret)
		lst (cdddr lst)
	  ) ;_ end of setq
     ) ;_ end of while
     (reverse ret)
) ;_ end of defun
(while (not e )(setq e (car (entsel "\nSelect base object > "))))
(setq eo (vlax-ename->vla-object e))
(princ "\nSelect intersection objects >")
(setq ss (ssget) i 0)
(repeat (sslength ss)
	(setq io (vlax-ename->vla-object (ssname ss i)))
	(setq int (pointlist3d(flatten(getintersections eo io))))
	(if (and int)(setq all (cons int all)))
	(setq i (+ i 1))
(setq all (flatten all))
(cond
	((and (setq f (getfiled "Output .csv file:" (getvar "dwgprefix") "csv" 3)))
		(setq
			outstring (strcat "\nIntersections points are saved to file: " f)
			file1 (open f "w")
			i -1
		(while (< (setq i (+ i 1)) (length all))
			(write-line
				(apply 'strcat
					(mapcar 'strcat
						(mapcar '(lambda (x) (rtos x 2 3)) (nth i all))
				file1
		(princ outstring)
		(close file1)
(princ)
(princ "\nType INTERSECTIONS to run command")
(princ)
Miljenko Hatlak
Message 28 of 52
WOW! Thanks a lot sir 😄
Message 29 of 52
@Patchy  Sir, I am sorry. I am unable to use Point Manager, which you referred.
Could you please tell me the details procedure? 😞
Message 30 of 52
Patchy
Need to run this :
https://www.cadstudio.cz/en/download.asp?file=IntLines
to get the nodes (Points)
then use the PT manager.
Message 31 of 52
OK sir
Message 32 of 52
Sir it looks like this
Message 33 of 52
Patchy
You mean the point style? change it using DDPTYPE
Message 34 of 52
Sir, I know about ddtype. But. In your drawing, there are point number also. after that, I used PTM. Input as Point and Output as file. Get output, but not like you.
Message 35 of 52
Patchy
I forgot to mention that feature was using Land Desktop (Now Civil 3d)
PT manager was the alternative to get your xyz.
You have to get Civil3d to do that.
Message 36 of 52
hak_vz
@Anonymous  Describe how you want your points record to be created, and I will update my script.
You don 't  need to use 5 scripts to extract something as simple as object intersections.
How you want it: let say
Point number, x,y,z,......
Miljenko Hatlak
Message 37 of 52
Patchy
It's easy to extract XYZ, but it's not easy to tell where the XYZ from Xcel taking from the drawing without labeling the point.
Message 38 of 52
hak_vz
Everything can be done but the task has to be clearly set. How points should be labeled, in what direction. Do he needs them arranged by intersection object  or else. It can be done automatically through the script, or simply by picking points at order in humanly more acceptable manner.
Miljenko Hatlak
Message 39 of 52
@hak_vz  sir, I want a excel sheet where x y and z value will save in different column. And I need the distance from the p point as well in excel sheet in different column.
I have attached a pic. Here the blue line is an arbitrary object. it will cut by red lines. I need the distance of every intersection point from point P.
If I can name every line as 1, 2, 3... it will more helpful for me. I have also attached a sample excel chart.
Message 40 of 52
hak_vz
OK. I will update the code tomorrow. It is a little bit late here at my location. Before writing  down the code lets define center point P. It is supposed to be placed at P(0,0).
Is this some arbitrary point or it has to be something like center of mass to enclosing object. Instead creating red lines to go across whole object we will have a set of lines that spreed from point P. Are this lines needed in your further work, or we can create intersection points for a set of line that enclose some angle (let say every 5 deg).
Do you want to have a point P selected from a script, or let me assume it is 0,0.
Do you need point object created  at intersection or just label text displaced for some distance in direction of a red line?
Since this is a 2D problem is Z coordonate needed?
What precision you need (2 3 or more decimal places)?
Are corner point of enclosing object also needed?
Angle from point p to intersection point added to table?
What about dividing each segment of  enclosing object at peaces of equal length (some step value).
With your method as stated now you will have a segments of enclosing object in "shaddow" zone, so it meigth
happen you won't have intersection points at that position. See upper right corner of your sample for clearance.
Answer this questions line by line after quoting separately each my question.
Miljenko Hatlak
