Fillet and Chamfer, but avoiding the obligation for the segments to "be consecutive or separated by one segment"
aitorm
aitorm
I like how the Fillet and Chamfer commands also join lines. I use it a lot. I also like how if you Fillet or Chamfer the very last segment of the polyline with the first segment, it does close de polyline. But I don't understand why if I try to Fillet or Chamfer one segment that is not the last one with the first segment, it doesn't do it! it says: "Lines belonging to polylines must be consecutive or separated by one segment"
So I would love if you could help me create a LISP that allows me to do this, maybe eliminating every segment that is after the one I want to chamber.
Thanks a lot.
Sea-Haven
When drawing a pline use the "C" option rather than "Enter" then it will close the last point to the first point. See if that fixes.
aitorm
Thanks for your answer. I know I can do that, but it is not what I a
looking for.
Sea-Haven
Post a dwg that does not work.
Kent1Cooper
I would want to see an image or drawing of a "before" Polyline showing where it starts/ends, the places you want to pick on it, and the "after" result you intend.  I think I understand what you want, but this would confirm or correct my assumptions.
Kent Cooper, AIA
komondormrex
aitorm
Thanks, that is exactly what I mean. Here a video in case it helps:
