Draw order based on BlockName
cliffordcudal
cliffordcudal
I'm trying to create lisp that will set draw order based on block name. can anyone check the code, it does not work when I try it. Thanks
(defun c:xblk (/ s blockList)
(setq blockList '("__4_Structure" "__3_Beam" "__2_Purlins" "__1_Modules)) ;  top-most first
(foreach blk blockList
(if (setq s (ssget "_X" (list (cons 2 blk))))
(command "_.draworder" s "" "_front")
(prin1)
komondormrex
hey,
syntax only corrected
(defun c:xblk (/ s blockList s)
(setq blockList '("__4_Structure" "__3_Beam" "__2_Purlins" "__1_Modules")) ;  top-most first
	(prin1)
cliffordcudal
It works, Thank you!
