How to avoid "current viewport layout" when (ssget "a") in an empty layout space
le-tan-phuc
le-tan-phuc
I have a problem when create a selection set with "ssget" in an empty  layout (have no visible object).
I think the selection set must be "nil" but it still exist an entity.
Command: (setq ss (ssget "a"))
<Selection set: c9>
Command: (entget (ssname ss 0))
((-1 . <Entity name: 185d50852b0>) (0 . "VIEWPORT") (5 . "2A3") (102 . "{ACAD_XDICTIONARY") ...
Some one please show me the way to not get this entity into selection set. thank you !
Sorry for my bad English
Accepted solutions (3)
ВeekeeCZ
Try this
(ssget "_X" '((0 . "VIEWPORT") (-4 . "<>") (69 . 1)))
Kent1Cooper
The "A" and "X" modes in (ssget) will still see other things in other Layouts and in Model space.  But if that's OK, and what you want is simply for it to not see any Viewports, you can forbid it to see them:
(setq ss (ssget "_A" '((0 . "~VIEWPORT"))))
Kent Cooper, AIA
paullimapa
in addition to @Kent1Cooper post, you may also want to include filter to look only in the current layout:
(setq ss(ssget "_X" (list '(0 . "~VIEWPORT") (cons 410 (getvar "ctab")))))
Paul Li
IT Specialist
@The Office
le-tan-phuc
Thanks for your help guys !
I found the solution to this problem.
From Vietnam, 8:20 AM-(UTC+07:00)
