export attribute block to shapefile with block attribute table
I have block attribute to export the files with block attributes, I tried following command of mapexport but its not exporting any attributes.
(command "-mapexport" "shape" Path "n" "s" "point" "m" selection set "" "*" "*" "n" "o" "y" "proceed")
attached file of jpeg which attribute is needed.
CodeDing
@Anonymous ,
Mine appears to have 2 more options than you are accounting for..
(command "-mapexport" "shape" Path "n" "s" "point" "m" selection set "" "*" "*" "n" "o" "y" [option1] [option2] "proceed")
See images.
Best,
~DD
I tried to put "LL84" & "N" in options but its not working
CodeDing
@Anonymous ,
What does your command history say when you try to run it? Can you Copy/Paste
(COMMAND "-mapexport" "shape" Path "n" "s" "point" "m" selection"" "*" "*" "n" "o" "y" "ll84" "y" "proceed")
its not inspecting is there is missing anything....
I am attaching block file for export in shp
