Need help Plotting modification
Hi All,
I have tried this code for PDF it is working perfectly. But I need to Plot PNG by modifying this same code. Please help me to modify this code for the following plotter.
Following are the details of my required Plotter:-
Plotter Name:- Portable Network Graphics PNG.pc3
Plot Style:- WF-B&W.ctb
Paper Size:-15000 x 8500 pixels
Plot offset:- Center the plot
Plot Scale:- Fit to paper
Drawing orientation:-Landscape
Plot option:- Mark Plot objects lineweights, Plot transparency, and Plot with Plot styles
Akash
Sea-Haven
This is a plot to tiff of all your layouts,  with a fixed title size. I can not see why your changing pc3 files. Once set up as you suggest by pixel size. To maintain dpi you would need multiple sheet sizes to match title size. If you just have a couple easier to make individual versions.
Hi @Sea-Haven ,
Thanks for your support but could you please create a complete code with png setup, so that I can modify with my required settings.
As I'm just started learning the AutoLISP on my own so I need your help.
Akash
