What did I do wrong?
Rikkes
Rikkes
I have a problem with this lisp file to insert a block.
This is the lisp file:
(defun c:kastbasis ()
(command "view" "top")
(command "dimstyle" "Restore" "Model 40")
(command "insert" "D:\Utilities\ACAD\ACad Sjablonen\kastbasis.dwg" (getpoint "\nSelect insertion point: ")
    "1" "0" )
  (princ)
I get an error message, this is it. All the backslashes are gone...
How can I resolve this?
Current dimension style: Layout 2 Annotative: No
Enter a dimension style option
[ANnotative/Save/Restore/STatus/Variables/Apply/?] <Restore>: Restore
Enter a dimension style name, [?] or <select dimension>: Model 40
Current dimension style: Model 40 Annotative: No
Command: insert Enter block name or [?]: D:UUtilitiesACADACad
Sjablonenkastbasis.dwg
"UUtilitiesACADACad Sjablonenkastbasis.dwg": Can't find file in search path:
C:\Users\Rikkes\Documents\ (current directory)
D:\Utilities\ACAD\Huis\Living\
C:\Program Files (x86)\MSPT\
C:\Users\Rikkes\appdata\roaming\autodesk\autocad 2011\r18.1\enu\support\
C:\programdata\caelink\
C:\program files\autodesk\autocad 2011\support\
C:\program files\autodesk\autocad 2011\fonts\
C:\program files\autodesk\autocad 2011\help\
C:\program files\autodesk\autocad 2011\support\color\
C:\Program Files\Autodesk\AutoCAD 2011\drv\
*Invalid*
; error: Function cancelled
cadffm
"D:/Utilities/ACAD/ACad Sjablonen/kastbasis.dwg"
"D:\\Utilities\\ACAD\ACad Sjablonen\\kastbasis.dwg"
(alert "1\n2")
(alert "1/n2")
(alert "1\\n2")
\n as example for a valid formatcode..
Help [F1] - About Strings (AutoLISP)
Sebastian
dbhunia
Try like this
(command "insert" "D:\\Utilities\\ACAD\\ACad Sjablonen\\kastbasis.dwg" (getpoint "\nSelect insertion point: ")
    "1" "1" "0" )
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Sea-Haven
Checkout using -Insert as filedia is auto turned off.
