simple routine does not work anymore in version 2019
pdn
pdn
Hello there
scratching my head, the following simple routine to get the colorobject table has always worked without any problem on versions 2013, 2015 and 2017 but in version 2019 it returns an error
;; get the colorobject table depending on ACAD version
(defun getcolorobject ()
(vla-getinterfaceobject
(vlax-get-acad-object)
(strcat "AutoCAD.AcCmColor." (substr (getvar "acadver") 1 2))
in previous versions I get <VLA-OBJECT IAcadAcCmColor 000000004160f250> back but 2019 gives me
error: Automation Error. Problem in loading application
any idea where to look for, maybe I used it wrong for all the time
Thanks in advance
Patrick
dbroad
Works fine here (AutoCAD 2019)
Architect, Registered NC, VA, SC, & GA.
CodeDing
@pdn ,
Works fine for me also in 2018.
Perhaps try including (vl-load-com)? Maybe it is not being loaded anymore.
EDIT:
Also, how are you calling this function? Do any error messages appear when LOADING your lisp?
Best,
~DD
Scottu2
Hi pdn,
Verify that the routine exists.
At the command line enter the IF statement below. A result of 1 = yes the routine exist, 0 = no routine
If you get a 0 (zero) then i suspect the registry a file link is missing, Click Here.
(if vla-getinterfaceobject 1 0)
(if vlax-get-acad-object 1 0)
Also try,
(if vlax-ename->vla-object 1 0)
Scott
pdn
OK
turned out to happen only on one system (for the moment, will have to check with the other users)
I had to uninstall completely ACAD 2019 (even had to use MicrosoftProgram_Install_and_Uninstall.meta.diagcab) and re-install from scratch
regards
Patrick
