Visual LISP, AutoLISP and General Customization
error in code using member function
7 REPLIES 7
Message 1 of 8
M_H_G_M_G
259 Views, 7 Replies
Hello every one
this a part of code and this inside a cond function
I've a list with name ColumnB and i need to make
if member in columnB equal any item of the list
'("ACROW FRAME-P" "Shore Brace Frame (H) (plan) 6221177009366" "CUPLOCK PLAN" "beam bracket" "cant. bracket(Plan)1")
make the function that i've made (
insert-spigot-jack-plate)
then i've a problem that the function (insert-spigot-jack-plate) repeated by the number of matching between the ColumnB and the list  '("ACROW FRAME-P" "Shore Brace Frame (H) (plan) 6221177009366" "CUPLOCK PLAN" "beam bracket" "cant. bracket(Plan)1")
if the 5 items exist in columnB list the function (insert-spigot-jack-plate) repeated 5 times
i just need to make it one time if one item at least exist or even the five items exist
How to make this
thanks in advance
             (member ColumnB '("ACROW FRAME-P"
                               "CUPLOCK PLAN"
                               "beam bracket"
                               "cant. bracket(Plan)1"))
             (progn
            (insert-spigot-jack-plate "Base Jack" jack_total jack_calc)
            (insert-spigot-jack-plate "Base Plate" plate_total plate_calc)
            (insert-spigot-jack-plate "U-Head Jack" U_Head_total  U_Head_calc )
7 REPLIES 7
Message 2 of 8
ec-cad
in reply to: M_H_G_M_G
Something like this might do it.
           (setq FLAG 0); Init Flag value ; add this somewhere above, in loop
; START of Cond
                               "CUPLOCK PLAN"
                               "beam bracket"
             (progn
;; ADD
              (if (= FLAG 0)
               (progn
                (setq FLAG 1)
               ); progn
              ); if
;; END OF ADD
;; END of Cond
ECCAD
Message 3 of 8
M_H_G_M_G
in reply to: ec-cad
Thanks sir
it works correctly
Message 4 of 8
ec-cad
You are very welcome. Come back anytime.
ECCAD
Message 5 of 8
ec-cad
Sent you a PM on it. Your latest code fragment is attached, along with a test drawing.
Seems to work now. Look for "<---" comments, showing what I changed.
ECCAD
Message 6 of 8
M_H_G_M_G
in reply to: ec-cad
yes sir
thanks it worked correctly …
Message 7 of 8
ec-cad
Good, glad to hear that !
I know you need more data types to add, should be a huge program once completed.
You (could) save those portions you are not using (outside) the main program, cut/paste
back in when needed. Just a suggestion.
And, make 'specific' functions to call the sorting routines.
One sample would be to put the 'new' Table startup into a seperate function, and call it.
ECCAD
Message 8 of 8
M_H_G_M_G
in reply to: ec-cad
thanks sir
it's a good idea
I sent something to you in the mail
Forma Design Contest
AutoCAD Beta
