ChatGPT - Autocad
ChatGPT - Autocad
ask_ahmed
ChatGPT - Autocad
ask_ahmed
https://www.youtube.com/watch?v=006Xnj7Cu1E&t=75s
I want to share an example where I have used Open AI ChatGPT to auto generate a lisp that calculates the area of a polygon.
However, I should note that generating AutoCAD lisps is not a typical use case for OpenAI. AutoCAD lisp is a scripting language used to automate repetitive tasks in AutoCAD software. While OpenAI can generate code, its primary application is in natural language processing, text generation, and other language-related tasks.
Thank you
LDShaw
I've been trying to use @CodeDing AI
for For Fun
I give it full credit for remarking my code now.
Please add this information as a header I want all lisp routines I am about to give you.
Please use this header information on lsp. I only want the header
- `Lisp Name` specifies the name of the Lisp routine.
- `Author` indicates the author's name.
- `Date Created` is the date when the routine was initially created.
- `Last Edited` shows the date of the most recent edit.
The `DESCRIPTION` section provides a brief overview of what the routine does, and the `Usage` section offers step-by-step instructions for using the routine, including any optional parameters.
The `Parameters` section lists the inputs required for the routine and their descriptions. Similarly, the `Returns` section describes what the routine provides as output.
Finally, the `Notes` section can include any additional information or customization options, and the header ends with the standard line:
;;; ---------------------------- Main program --------------------------------;
This standardized header format makes it easy for users to understand and use AutoLISP routines.
