Draw Polyline
Draw Polyline
SilentStrike24
Message 1 of 25
Draw Polyline
SilentStrike24
Hello all. Do you know if there's any free routine that makes the following?
I need to create the green polyline and the lengths A, B, C, D should be questioned.
C and D are always perpendicular on the original lines and they're at a specific distance from the ends (meaning lengths A, B).
Desired endpoints of the original lines should be the nearest endpoints to the cursor selection (needed when calculating from which end you want distances A, B).
Also, this polyline should always be on the smaller angle side, if you think at 360°.
Thanks!
Replies (24)
Message 21 of 25
SilentStrike24
Hi @CADaSchtroumpf,
Now it creates those lines too. Thank you very much.
Message 22 of 25
CADaSchtroumpf
Glad it finally works ....
Just a warning:
If USERR1 (or 2) have a value of zero, a duplicate vertex will be created (this can cause hatching problems). If they have a negative value, the angle will no longer be 90 ° (this can be solved by replacing in the code (getvar 'USERRx') by (abs (getvar 'USERRx')) 4 occurrences)
Reminder: the command applies the chamfer to all the vertices of the polyline (if it is possible!)
Message 23 of 25
SilentStrike24
Ok, thanks for the info's!
Message 24 of 25
Kent1Cooper
,,, never mind ...
Kent Cooper, AIA
Message 25 of 25
hutre12386
Community Visitor
Community Visitor
Draw a Boundary Polyline
  1. Click the Home tab and Draw the panel Boundary. Find.
  2. In the Boundary Creation dialog box, Object Type list, select Polyline.
  3. Click Pick Points. Specify points within each area to form a boundary polyline for each.
  4. Press Enter to create the boundary polylines and end the command currently, I am doing work on temple run oz mod apk 2021.
