Renaming Layers after PDF Import - Removing the "PDF_" Prefix and merging similar layers.
mrjackgill
mrjackgill
Thanks in advance for your help!
The Scenario: When I import a PDF file Autocad adds a prefix of "PDF#_" to all the layers.
If you import several PDFs then you get incremented prefixes (PDF_LayerName, PDF2_LayerName, PDF3_LayerName, PDF4_LayerName....). The "#" symbol is never part of the prefix.
If you start with a document that has 50 layers and the PDF you are importing also has 50 layers and u import 5 of them you then have 300 layers (250 new layers + 50 from your original document). Many imported layers may have the same name as layers in your original document but they will have the PDF#_ prefix (ie Layer 0 (from original document), PDF_Layer 0 (imported), PDF2_Layer 0 (imported), PDF3_Layer 0 (imported), PDF4_Layer 0 (imported), PDF5_Layer 0 (imported).
I would like to be able to do the following: search through all the layers and find any with a "PDF#_" prefix (ie PDF#_Layer 0). If one is found then scan the list of layers to see if there is a layer with the same name excluding the prefix (Layer 0) and merger these into Layer 0.
Assuming my original document had 50 layers and the pdf i was importing had 50 layers and the layer names were the same in both models then this script would take my 300 layer document (after 5 imports) back to a 50 layer document.
I got some help to get this far (from a few of you - I apologize if I have mangled your code) but it still doesn't work and I am lost as to how to fix it.
(defun C:PDFLM ; = PDF Layer Merge
  ;Define three variables
  (/ Elayer PDFlayer NEWname)
  ;Iterate through the list of layer names - store each layer in "Elayer" then test
  (while (setq Elayer (tblnext "layer" (not Elayer)))
  ;Look for any layer with a PDF in the name and store that name in "layname"
    (setq PDFlayer (cdr (assoc PDF lay)))
    ;Look for an existing layer with same name (wihout PDF prefix)
      (if (tblsearch "layer" (setq NEWname (substr PDFlayer (+ (vl-string-search "_" PDFlayer) 2))))
      ;If there is an existing layer with the same suffix - merge
        (command "_.laymrg" "_name" PDFlayer "" "_name" NEWname "_yes"); then
        ;If there no layer with the same suffix exists - remove prefix and save as suffix
        (command "_.rename" "_layer" PDFlayer NEWname); else
      ); if
    ); if
  ); while
  (princ)
); defun
Thank You!!
hak_vz
Try this. Code is not fully tested since it is getting late here at my location.
(defun C:PDFLM(/ Table dwg_layers  pdf_layers)
	(defun Table (s / d r)
		(while (setq d (tblnext s (null d)))
			(setq r (cons (cdr (assoc 2 d)) r))
	(foreach lay (Table "layer")
		(if (= (substr lay 1 4) "PDF_")
			(setq pdf_layers (cons lay pdf_layers))
			(setq dwg_layers (cons lay dwg_layers))
	(foreach lay pdf_layers
		(if (member (substr lay 5) dwg_layers)
			(command "_.laymrg" "_name" lay "" "_name" (substr lay 5) "_yes")
			(command "_.rename" "_layer" lay (substr lay 5))
(princ)
If it works for you, accept this post as a solution.
Miljenko Hatlak
mrjackgill
Thank you VERY much for the reply...I think this could work but I don't understand how it handles the incremented PDF#_ layer names as it appears to test for just "PDF_".  The layer prefix could be any of the following: PDF_ (in which case this would work - although I haven't run it yet), PDF1_, PDF2_, PDF3_, PDF4_, PDF5_, etc...
Thanks!!
hak_vz
Miljenko Hatlak
hak_vz
Try this. It works on my test case.
(defun C:PDFLM(/  *error* Table dwg_layers  pdf_layers get_layers)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ (strcat "\nError: " msg))
		(princ)
	(defun get_layers ()
			(if (= (substr lay 1 3) "PDF")
	(setvar 'cmdecho 0)
	(get_layers)
		(get_layers)
		(if (member (substr lay (setq pos (+ (vl-string-search "_" lay) 2))) dwg_layers)
			(command "_.laymrg" "_name" lay "" "_name" (substr lay pos) "_yes")
			(command "_.rename" "_layer" lay (substr lay pos))
	(princ)
Miljenko Hatlak
