Draw Polyline
Draw Polyline
SilentStrike24
Message 1 of 25
Draw Polyline
SilentStrike24
Hello all. Do you know if there's any free routine that makes the following?
I need to create the green polyline and the lengths A, B, C, D should be questioned.
C and D are always perpendicular on the original lines and they're at a specific distance from the ends (meaning lengths A, B).
Desired endpoints of the original lines should be the nearest endpoints to the cursor selection (needed when calculating from which end you want distances A, B).
Also, this polyline should always be on the smaller angle side, if you think at 360°.
Thanks!
Replies (24)
Message 2 of 25
Sea-Haven
Is this not the same as the post requesting "CHAMFER" answer about 2 weeks ago, I will check maybe its on another forum. I know I posted as had questions. It was a double chamfer question.
Message 3 of 25
SilentStrike24
Yes, it’s the same idea.
I hope i‘m not “breaking” forum rules by posting again, but i urgently need a solution for this one.
And for that topic i got no help till now, so i thought posting again would be a solution.
I guess no one’s looking in posts from 2-3 weeks ago to solve, anymore.
If that’s not ok, i’ll delete it and search for guidance somewhere else.
Message 4 of 25
john.uhden
I am curious.  You presented an image, so aren't you capable of doing this using stock AutoCAD commands?
What, do you have hundreds of them to do and the boss is allowing only 5 minutes to do the work?  He should rethink his budget.  Maybe it's funny but when I need my shrubs trimmed I can never find anyone to do it for free, and especially in just 5 minutes.
John F. Uhden
Message 5 of 25
SilentStrike24
Hi @john.uhden,
You’re thinking is right. Want something, you should pay for it, or “rethink the budget”:))
But i guess this is the point of this kind of forums: get in touch with people having the same hobbies, share ideas and, consequently, help others improve.
Regarding your shrubs, I’ve seen here custom made routines of hundreds of code lines, i hardly believe my question is that hard. So what should be free and what not?
If you wanna help, help; if you consider this is a must-pay or an extremely difficult task, move on. It’s that simple.
FYI: no boss is asking me for this. It’s me who’s trying to ease my day to day work. So if you think i earn money for this polyline, you couldn't be more wrong.
Message 6 of 25
Sea-Haven
This is the code, Its not hard draw a circle from IP, from the 2 points draw a 90 line of length, join a new line end of the 2 lines.
OOPS method not code.
It is not a bad task to start learning lisp. Google "draw line perp from line lisp autocad"
Message 7 of 25
SilentStrike24
Thanks for the help, @Sea-Haven.
I’ll try to solve it.
Message 8 of 25
ВeekeeCZ
(defun c:Chamfer2 ( / ap av am bp bm ag ps pe)
  (if (and (or *ch-a* (setq *ch-a* 2.))
	   (setq *ch-a* (cond ((getdist (strcat "\nSpecify distance A <" (rtos *ch-a*) ">: "))) (*ch-a*)))
	   (or *ch-b* (setq *ch-b* 2.))
	   (setq *ch-b* (cond ((getdist (strcat "\nSpecify distance B <" (rtos *ch-b*) ">: "))) (*ch-b*)))
	   (or *ch-c* (setq *ch-c* 0.5))
	   (setq *ch-c* (cond ((getdist (strcat "\nSpecify distance C <" (rtos *ch-c*) ">: "))) (*ch-c*)))
	   (or *ch-d* (setq *ch-d* 0.5))
	   (setq *ch-d* (cond ((getdist (strcat "\nSpecify distance D <" (rtos *ch-d*) ">: "))) (*ch-d*)))
    (while (and (setq ap (cadr (entsel "\nSelect AD object: ")))
		(setq av (osnap ap "end"))
		(setq am (osnap ap "mid"))
		(setq bp (cadr (entsel "\nSelect BC object: ")))
		(setq bm (osnap bp "mid"))
		(setq ag (- (angle av bm) (angle av am)))
		(setq ag (if (< ag 0) (+ ag pi pi) ag))
      (command "_.pline"
	       "_non" (setq ps (polar av (angle av am) *ch-a*))
	       "_non" (polar ps ((if (< ag pi) + -) (angle av am) (/ pi 2)) *ch-d*)
	       "_non" (polar (setq pe (polar av (angle av bm) *ch-b*))
			     ((if (< ag pi) - +) (angle av bm) (/ pi 2))
			     *ch-c*)
	       "_non" pe "")))
  (princ)
Message 9 of 25
Kent1Cooper
I would change the wording of one prompt:
 .... "\nSelect AD object closer to its end that meets BC object: " ....
I suspect [without testing] that the result would go wonky if it is selected closer to its other end.
Or, the issue could be avoided [both AD and BC objects could be selected anywhere] by also saving the result of using ENDpoint Osnap on the BC object, and using (inters) with the endpoints and midpoints of both to determine the 'av' variable [where the two meet].
Kent Cooper, AIA
Message 10 of 25
SilentStrike24
Thanks for the help @ВeekeeCZ !
Code works perfect. It saves me a lot of time.
One more thing if i'm not asking too much, you know if the code can be updated so it can work on polylines too? You can see below how it is drawn when having polylines.
Anyway, thanks again for your time.
Message 11 of 25
CADaSchtroumpf
I tried to start from the 'CHAMFER' command with the 'polyline' option to apply the principle of this special chamfer to all the vertices.
It remains a test, it seems to work but I certainly did not consider all the scenarios: it was more complicated than I thought.
(vl-load-com)
(defun add_vtx (obj add_pt ent_name fz / sw ew nw bulg next)
  (vla-GetWidth obj (fix add_pt) 'sw 'ew)
  (vla-addVertex
    obj
    (1+ (fix add_pt))
    (vlax-make-variant
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbdouble (cons 0 1))
          (list
            (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
            (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
  (setq next (1+ (fix add_pt)))
  (while (equal (vlax-curve-getdistatparam obj next) (vlax-curve-getdistatparam obj (fix add_pt)) fz)
    (setq next (1+ next))
  (setq
    nw
        (- ew sw)
        (- (vlax-curve-getdistatparam obj next) (vlax-curve-getdistatparam obj (fix add_pt)))
      (- (vlax-curve-getdistatparam obj add_pt) (vlax-curve-getdistatparam obj (fix add_pt)))
    bulg (atan (vla-GetBulge obj (fix add_pt)))
  (vla-SetBulge obj
    (fix add_pt)
      (sin (* 4 bulg (- add_pt (fix add_pt)) 0.25))
      (cos (* 4 bulg (- add_pt (fix add_pt)) 0.25))
  (vla-SetBulge obj
    (1+ (fix add_pt))
      (sin (* 4 bulg (- (1+ (fix add_pt)) add_pt) 0.25))
      (cos (* 4 bulg (- (1+ (fix add_pt)) add_pt) 0.25))
  (vla-SetWidth obj
    (fix add_pt)
    sw
    (+ nw sw)
  (vla-SetWidth obj
    (1+ (fix add_pt))
    (+ nw sw)
    ew
  (vla-update obj)
(defun c:chamfer_po ( / lst_var js ent dxf_ent lst_pt new_lst_pt dfzz ob pt1 pt2 pt_m deriv alpha v1 v2 det_or nw_pt prm pt@subst)
  (mapcar '(lambda (x) (setq lst_var (cons (getvar x) lst_var)))
    '("CMDECHO" "TRIMMODE" "CHAMMODE" "COMMANDPREVIEW" "PROJMODE")
  (mapcar '(lambda (x y) (setvar x y))
    '(1 1 0 1 1)
  (mapcar
    '(lambda (x)
      (command "_.SETVAR" x
        (while (not (zerop (getvar "CMDACTIVE")))
          (command pause)
    '("CHAMFERA" "CHAMFERB" "USERR1" "USERR2")
  (princ "\nSelect polyline")
  (while (null (setq js (ssget "_+.:E:S" '((0 . "LWPOLYLINE") (-4 . ">") (90 . 2)))))
    (princ "\nOject isn't valide")
  (setq
    ent (ssname js 0)
    dxf_ent (entget ent)
    lst_pt (mapcar '(lambda (x) (trans x ent 1)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
  (command "_.CHAMFER" "_Polyline" ent)
  (setq
    new_lst_pt (mapcar '(lambda (x) (trans x ent 1)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
  (setq dfzz 1E-08)
  (foreach el lst_pt
    (setq new_lst_pt (vl-remove-if '(lambda (x) (and (equal (car x) (car el) dfzz) (equal (cadr x) (cadr el) dfzz))) new_lst_pt))
  (cond
    (new_lst_pt
      (setq ob (vlax-ename->vla-object ent))
      (if (not (zerop (logand 1 (cdr (assoc 70 dxf_ent)))))
        (setq new_lst_pt (append (cdr new_lst_pt) (list (car new_lst_pt))))
      (while (cdr new_lst_pt)
        (setq
          pt1 (car new_lst_pt)
          pt2 (cadr new_lst_pt)
          pt_m (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5 0.5))
          deriv (vlax-curve-getfirstderiv ent (1- (vlax-curve-getparamatpoint ent (vlax-curve-getClosestPointTo ent pt1))))
          alpha (- (atan (cadr deriv) (car deriv)) (angle '(0 0 0) (getvar "UCSXDIR")))
          v1 (mapcar '- (polar pt1 alpha 1.0) pt1)
          v2 (mapcar '- pt_m pt1)
          det_or (apply '(lambda (x1 y1 z1 x2 y2 z2) (- (* x1 y2) (* y1 x2))) (append v1 v2))
          nw_pt (trans (polar pt1 (if (> det_or 0.0) (+ alpha (* pi 0.5)) (- alpha (* pi 0.5))) (getvar "USERR1")) ent 0)
          prm (vlax-curve-getparamatpoint ent (vlax-curve-getClosestPointTo ent (trans (polar pt1 (angle pt1 pt2) (getvar "USERR1")) ent 0)))
        (add_vtx ob prm ent dfzz)
        (setq
          pt@subst (nth (1+ (fix prm)) (mapcar '(lambda (x) (trans x ent 1)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) (setq dxf_ent (entget ent))))))
          dxf_ent (subst (cons 10 (list (car nw_pt) (cadr nw_pt))) (cons 10 (list (car pt@subst) (cadr pt@subst))) dxf_ent)
        (entmod dxf_ent)
        (setq
          deriv (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent (vlax-curve-getClosestPointTo ent pt2)))
          nw_pt (trans (polar pt2 (if (> det_or 0.0) (+ alpha (* pi 0.5)) (- alpha (* pi 0.5))) (getvar "USERR2")) ent 0)
          prm (vlax-curve-getparamatpoint ent (vlax-curve-getClosestPointTo ent (trans (polar pt2 (angle pt2 pt1) (getvar "USERR2")) ent 0)))
        (setq
        (entmod dxf_ent)
        (setq new_lst_pt (cddr new_lst_pt))
    (reverse lst_var)
  (prin1)
Message 12 of 25
SilentStrike24
Hi @CADaSchtroumpf , thank you for the time! It looks like a lot of work!
Still, i tested it and it does a chamfer, not the polyline showed in my picture.
Please see above @ВeekeeCZ's code. It works exactly as it should. Only thing is that it's not working when having polylines as the dependent objects.
Thanks anyway for the work!
Message 13 of 25
CADaSchtroumpf
Did you well inform the variables 'USERR1' (for chamferC) and 'USERR2' (for chamferD) at the beginning of the procedure?
If these values ​​remain at zero, it comes back to the "chamfer" command with the "polyline" option ...
Message 14 of 25
Sea-Haven
I dont see a problem pick 1 point at intersection is it 2 lines or a single pline, for 2 lines use the circle approach. For a pline ptatdist and 1st deiriv for angle. Oh yeah pick point is actually (ssget "F" say 4 points like pickbox a small box. Then can know if 2 objects, a line/pline is ok also.
Next question for pline straight and then lots of segments what is "A" & "B" distance a radial or distance along from point ? The get1stderiv will allow code for draw a line at 90 from the pline point.
Message 15 of 25
SilentStrike24
Hi @CADaSchtroumpf,
Yes, i did. Please see below picture.
Apparently, if I change variables "USERR1"/"USERR2" or not,  it still asks for a polyline and the result is the same.
Message 16 of 25
CADaSchtroumpf
I see in your picture:
Command; error: no function definition: VLAX-ENAME->VLA-OBJECT
I have put the function (vl-load-com) in the first line in my code, have you copied also this?
Otherwise, I don't understand the problem
Message 17 of 25
SilentStrike24
I may have a problem with the file needed for (vl-load-com), meaning vlcom.dll.
I'll fix it and retry your function.
Message 18 of 25
SilentStrike24
Hi @CADaSchtroumpf,
Solved the problem with that .dll. Meaning i reinstalled the software 🙄
I got rid of that error, but there's another one. Please see below picture.
And consequently, it keeps going with chamfer/polyline, even if i change variables.
Message 19 of 25
CADaSchtroumpf
Can you join a exemple drawing where the function don't work's
In this case this is my code is not good 😣
Also I hace tested on 2019 version, what version you use?
Message 20 of 25
CADaSchtroumpf
I was able to reproduce the same error; when you are not in the WCS.
Try with the attached file, I think to have fixed the code.
