dBase,: Why Visual-Lisp not use CommonLisp-quick-informations?
diagodose2009
diagodose2009
CommonLisp describes, what he does each function after the line-defun.
Visual Lisp accepts this "Inf=" description.
(defun dfn_taskf2(langf)
 "Inf=Leave only one copy of the repeated elements"
(defun dfn_taskf4(lst)
  "Inf=Count the number of repeated occurrences"
(defun dfn_taskf5(lst)
  "Replace all elements with count inn reverse Order"
  (let ( ($rr nil)
         (lst3 nil)
(defun dfn_taskf1(vlc $rr)
 "Remove the second and succeeding adjacent duplicates"
 (if (and vlc (cadr vlc) (equal (car vlc) (cadr vlc)))
   (dfn_taskf1 (cdr vlc) $rr)
     (if (cadr vlc)
       (setf $rr (cons (car vlc) (dfn_taskf1 (cdr vlc) $rr)))
       (setf $rr vlc)
Can you test, inside Vlisp for Acad2020+ or Acad2021?
hak_vz
Because Visual lisp is not Common lisp (CL). More details here.
Miljenko Hatlak
