[LISP] Simplify the code
iBlachu
Message 1 of 22
iBlachu
Who can help me simplify the code below, the one that is between the START and END tags.
(setq L
	(list
		(list 0 1 2)
		(list 0 1 2)
		(list 0 1 2)
		(list 0 1 2)
(setq e 2)
(setq L1 nil)
(foreach
	x
	L
	; START
	(setq t nil)
	(setq i 0)
	(while (< i (length x))
		(if (not (equal i e))
			(setq t (reverse (cons (nth i x) (reverse t))))
		(setq i (1+ i))
	(setq L1 (reverse (cons t (reverse L1))))
	; END
(princ L1)
(princ)
Replies (21)
Message 2 of 22
ВeekeeCZ
First, NEVER use T as a variable. It's a protected symbol for True. (not T) = nil
Message 3 of 22
ВeekeeCZ
If your goal is
'(0 1 2) -> '(0 1)
then
(reverse (cdr (reverse '(0 1 2))))
'(0 1)
You can use your FOREACH, but you need to build another list (L1). Move convenient is to use a mapcar with anonymous func.
(setq L (mapcar '(lambda (x) (reverse (cdr (reverse x)))) L))
Message 4 of 22
iBlachu
Yes, but note that the variable "e" can be anything and the list L can also have lists of any length, not just 3 elements.
Message 5 of 22
ВeekeeCZ
So you need just the first 2 items?
(list (car x) (cadr x)), or... where's the catch?
Edit: Do a more complex example covering all possible cases.
Message 6 of 22
iBlachu
(setq L
	(list
		(list 0 1 2 3 4 5 6 7 8 9)
	(list
		(list 0 1 2 3 4 6 7 8 9)
My routine removes the selected item in all sublists. Thus, it can be indicated that we remove e.g. the 5th element (setq e 5) in such a list:
Message 7 of 22
ВeekeeCZ
Why you can't use some routine of those from your last thread?
Message 8 of 22
iBlachu
I was thinking more about using mapcar or lambda.
Message 9 of 22
ВeekeeCZ
(defun c:test ()
  (setq lst '((0 1 2 3 4 5 6 7 8 9) (0 1 2 3 4 5 6 7 8 9) (0 1 2 3 4 5 6 7 8 9))
	e 5)
  (mapcar '(lambda (sub)
	     (vl-remove-if
	       '(lambda (itm) (= e (vl-position itm sub)))
	       sub))
	  lst)
... it's the same approach as used HERE ...
Message 10 of 22
ВeekeeCZ
Do you understand how those works? Or is it just a black box.... and need some comments?
Message 11 of 22
ronjonp
@ВeekeeCZ  Your code will remove all occurrences if they exist:
Message 12 of 22
john.uhden
Hey, BeekeeCZ, that was going to be my answer!
In spite of that, it's a good one.
John F. Uhden
Message 13 of 22
john.uhden
Okay, where's the "dislike" button?
John F. Uhden
Message 14 of 22
ВeekeeCZ
@ВeekeeCZ wrote:
(defun c:test ()
	e 5)
	     (vl-remove-if
'(lambda (itm) (= e (vl-position itm sub))) sub)) lst) )
As @ronjonp well pointed out, this algorithm sacks. Dunno what I was thinking.
We need to include a counter there to match the current index in the list.
(defun c:test ()
  (setq lst '((4 5 6 6 6 6 7 8 9 10 11 12 13) (3 4 6 7 8 9) (3 4 6 6 7 8 9))
	edx 2)
  (mapcar '(lambda (sub / idx)
	     (setq idx -1)
	     (vl-remove-if
	       '(lambda (itm)
		  (= edx (setq idx (1+ idx))))
	       sub))
	  lst)
Message 15 of 22
Kent1Cooper
This removes a single item by position from a single list:
(defun RIFL (thelist itemno / prelist); = Remove Item From List
  (if (>= (length thelist) itemno)
    (progn ; then
      (repeat (1- itemno)
        (setq
          prelist (append prelist (list (car thelist)))
          thelist (cdr thelist)
        ); setq
      ); repeat
      (append prelist (cdr thelist))
    ); progn
    (progn ; else
      (prompt "List does not contain that many items.")
      (princ)
    ); progn
  ); if
); defun
(setq xyz '(1 2 3 4 5 5 5 6 7 8 9))
Command: (rifl xyz 1)
(2 3 4 5 5 5 6 7 8 9)
Command: (rifl xyz 6)
(1 2 3 4 5 5 6 7 8 9) [preserves multiples same as removed item]
Command: (rifl xyz 11)
(1 2 3 4 5 5 5 6 7 8 ) [really no space between 8 & ), but the website makes an emoji of them when together]
Command: (rifl xyz 15)
If applied across a list of sub-lists, presumably you wouldn't want that too-short-a-list message.  What should be done if one of the sub-lists does not contain as many items as the item number to be removed?  Should it simply be left alone?
Kent Cooper, AIA
Message 16 of 22
john.uhden
Dug this out of my tool box...
;; Tony Tanzillo (01-25-02)
(defun cut_nth (lst pos / head)
  (repeat pos
    (setq head (cons (car lst) head)
          lst (cdr lst)
  (append (reverse head) (cdr lst))
John F. Uhden
Message 17 of 22
ronjonp
Another for fun ( assuming a list not storing nil values ) 🙂
(defun _removenth (l n / i)
  (setq i -1)
  (vl-remove 'nil
			(if (/= n (setq i (1+ i)))
			  x
		     l
(_removenth '(0 1 2 3 3 4 5 6 7 8 9 10 10 10 11) 3)
;; (0 1 2 3 4 5 6 7 8 9 10 10 10 11)
Message 18 of 22
john.uhden
Pretty tricky @ronjonp
But how can we be sure which 3 you removed? 😜
John F. Uhden
Message 19 of 22
ronjonp
It removed the correct 3 adjacent to 2 😀
Message 20 of 22
john.uhden
@ronjonp
Okay, prove it! 👺
I had a friend Charlie in high school who dated identical twins, Donna and
Linda.
I'm pretty sure he never really knew which one he was with. But the girls
didn't mind. They were able to share and laugh about their experiences.
I think he ended up marrying Donna, but no one is really sure about that.
John F. Uhden
