Create LISP script for Object Snap overrides, like Revit's (SE > Snap Endpoints, SM > Snap Midpoints, etc.).
Intuos5
Advisor Advisor
Intuos5
Would it be possible to create an LISP script for snap overrides so that I can snap to Endpoints, Midpoints, Tangent, Intersection, Extension, etc. by typing in a two letter combination? And would this work within while editing a polyline with its handles or when the polyline command is active?
ВeekeeCZ
NO.
Imho the best option is Shift RightMouseClick + Letter. Key letters could be adjusted in CUI if differs from Revit. Also, it could be Shift/Ctrl or just another button if you have a gaming mouse.
Or you can redefine the entire layout of Ctrl combos to have Ctrl+Letter.
Intuos5
Allright, I see.
That's unfortunate. I wanted to map the shift+right click menu to a single button hotkey, but I couldn't overrride F1's help menu and the other ones are all in use. I dislike pressing RMB for menus if it occurs often. Thanks for the help.
ВeekeeCZ
Interesting idea.
F1 could be redefined, I had that for like 10 years. But lately (guess since 2019 version) there is a bug and no matter what you do, F1 still once in a while brings HELP window.
I recommend sacrificing some other F key.
Intuos5
Yeah, I have had some issues with other Autodesk software with F1 remapping (Revit, Fusion 360), I could override it in Max though.
rgrainer
