Lisp: Selected objects are not immediately visible
АлексЮстасу
Advisor Advisor
Message 1 of 9
АлексЮстасу
XDTOOLS_SELAPPS.lsp strangely select objects - this is the routine of selecting objects with the specified XData.
If there was a pre-selection of objects, the objects found by the routine do not have their grips highlighted. But they become visible if click in the graphical window.
How to fix it?
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Replies (8)
Message 2 of 9
ВeekeeCZ
Try this.
The point is to use (sssetfirst nil nil) ONLY when objects were preselected.
Edit: code updated. @АлексЮстасу
Message 3 of 9
АлексЮстасу
Thanks for the reply!
Unfortunately, this method did not help.
When preselected, the grips are still not immediately highlighted.
Message 4 of 9
ВeekeeCZ
Post simple test dwg and translate lisp to eng-latin to be able to test it.
Message 5 of 9
АлексЮстасу
All the messages were and are on googlenglish.
Yes, I thought it would be better to attach a test file as well...
Message 6 of 9
ВeekeeCZ
Ok, the code has been updated. The point is the same.
Message 7 of 9
АлексЮстасу
Yes! Bravo!
Thank you!
Grips are visible after selection in all options at once.
Message 8 of 9
АлексЮстасу
I'm not a programmer, and I'm writing by hearsay!
It's not about (sssetfirst nil) after all.
If exclude this line in your version, the result will be the same - grips are always highlighted.
And if I use another version - with "\nSelect objects <All>:" - then there's no problem with grips highlighting either.
I have attached this version here.
The real cause is unknown...
But this doesn't mean that I'm not grateful to you for your help!  🙂
Message 9 of 9
ВeekeeCZ
If you pre-select objects that all are lately filtered out (all have no xdata), they stay highlighted.
