Isolating viewport from the Model space
j.balasubramaniyam
j.balasubramaniyam
Hi  may be my question looks weird but we do have a requirment. Is there anyway to isolate the viewport from the model space and save the drawing. The layout should be visible with the model details but xreffed models will not be there & it is orphaned. Due to higher size we are not able to send the models. Any way??
ВeekeeCZ
Do I understand you correctly that you want to have a routine that removes all layouts but the current and detaches all xrefs and saves this as a copy?
j.balasubramaniyam
Hi, thanks for the reply. It could be a routine also fine. But is there a way to extract the layout contents only as a drawing when xreffed models are available? This will be useful if we are not able to send the Models with size in GB's. Thanks
