Converting Multiple AutoCAD drawing(.dwg) files to AutoCAD template(.dwt) files
I want to convert all my drawings (total 150) in a folder from .dwg to .dwt format.
Instead of opening every single file, and then doing "Save As", please suggest an alternative easy method.
Lavish
SeeMSixty7
use DOS
RENAME *.DWG *.dwt
as long as you want every dwg in that folder to be a template.
Hi SeeMSixty7,
That worked perfectly. I am done in seconds. 🙂
Thanks a lot.
Awesome blog. Will refer to it in the future.
Lavish
SeeMSixty7
Glad that worked!
Thanks!
