Copy All Objects From One Layer To New Layer w/o Selecting
Message 1 of 8
Hello Everyone,
I was wondering if someone can help me modify the lisp below. I would like to universally copy all objects from the "WB_0" layer to the "WB_MFG_REF" layer without selecting.
Any help is greatly appreciated.
Xi
;Written by Odie Silva on Feb 6,2002
 ;CPLAY duplicates selected entities to a specified layer.
 (defun c:LREF (/ ss lay pt1 pt2)
 (setvar "cmdecho" 0)
 (setq pt1 "0,0,0")
 (setq pt2 "0,0,0")
 (setq verlay (tblsearch "layer" "WB_MFG_REF"))
 (chklay)
 (setq lay "WB_MFG_REF")
 (setq lay (getstring (strcat "\nDestination Layer: " lay "?: ")))
 (if (/= lay "")
 (progn
 (setq verlay (tblsearch "layer" lay))
 (if (= verlay nil)
 (chklay)
 (setq ss (ssget))
 (command "copy" ss "" pt1 pt2)
 (command "change" ss "" "p" "la" lay "")
 (princ)
 (defun chklay ()
 (if (= verlay nil)
 (progn
 (initget "Y N")
 (setq ans
 (strcase
 (getkword
 "\nDefault layer dos not exist. Do you want to create it?: "
 (cond
 ((= ans "Y")
 (setq lay (getstring "\nEnter new layer name: "))
 (setq col (rtos (acad_colordlg 7) 2 0))
 (command "layer" "m" lay "c" col "" "")
 ((= ans "N")
 (princ "\nProgram Exited.")
 (exit)
Replies (7)
Message 2 of 8
SeeMSixty7
Try this.
This does the bulk of what you want, but it does not do the Layer Validation. You can use they layer validation function in your posted code and just add it in here.
(defun C:CPLAY()
   (setq cplay-ss (ssget "X" '((8 . "WB_0"))))
   (if cplay-ss
       (progn
           (command "copy" cplay-ss "" "0,0,0" "0,0,0" "")
           (command "change" cplay-ss ""  "p" "la" "WB_MFG_REF" "")
Good luck - Learn more by experimenting!
Message 3 of 8
ВeekeeCZ
Never like if the routine changes the original...
(defun c:Copy0ToRef ( / ss)
  (if (setq ss (ssget "_A" '((8 . "WB_0"))))
    (progn
      (or (tblsearch "LAYER" "WB_MFG_REF")
          (command "_.LAYER" "_N" "WB_MFG_REF" ""))
      (command "_.-COPYTOLAYER" ss "" "WB_MFG_REF" "_D" "0,0,0")))
  (princ)
Message 4 of 8
Wow ! That was fast.   It works wonderfully.
Thank you guys !
Message 5 of 8
And I thought that I was done.
How would I modify this lisp if Multiple layers were to be copied?
Message 6 of 8
ВeekeeCZ
'((8 . "WB_0,WB_1,WB_2"))
...like this. Delimited by a comma.
Message 7 of 8
ariskouros
How not to copy again to the layer when you run it for another time?
Message 8 of 8
ВeekeeCZ
@ariskouros
I have a little trouble understanding what you need. What is your ultimate goal? Maybe add some sample dwg with before and after.
In any case, I would recommend starting a new topic, as you'll get more attention that way.
Good luck.
