Converse string to list
Browning_Zed
Browning_Zed
Dear forum members, help.
How can a string be converted to a list?
"100,250,50"    >>>    '(100 250 50)
This is as an example. That is, when converting, the "x, x, x" pattern must be parsed into '(x x x).
Kent1Cooper
Will they always be whole numbers?  It makes a difference to which AutoLisp function is most appropriate to convert the pieces of text string to the numbers in the final list.
Kent Cooper, AIA
Kent1Cooper
@Kent1Cooper wrote:
Will they always be whole numbers?  ....
If they are, this seems to do it:
(defun TCD2LN ; = Text Comma-Delimited {to} List of Numbers
  (txt / LN)
  (while (wcmatch txt "*`,*"); still any comma(s)?
    (setq
      LN (cons (atoi (substr txt 1 (vl-string-position 44 txt))) LN)
      txt (substr txt (+ (vl-string-position 44 txt) 2))
    ); setq
  ); while
  (reverse (cons (atoi txt) LN)); add last number
); defun
Command: (TCD2LN "123,456,789")
(123 456 789)
Command: (TCD2LN "1,12,123,1234")
(1 12 123 1234)
It does not check whether the supplied text string is appropriate, but could be made to.
Kent Cooper, AIA
Browning_Zed
Yes, it will always be whole numbers. Thank you for your help.
pbejse
Another
(Defun _SNL (str);<-- String Numbers to List
(read (strcat "("
	(vl-string-translate  "," " " str) ")" 	))
_SNL
_$ (_SNL "100,250,50")
(100 250 50)
_$ (_SNL "1,12,123,1234")
(1 12 123 1234)
HTH
pbejse
Re: Converse string to list
A literal solution  😊
Sea-Haven
May be known as laces only $10 add to shopping LIST.
