Copy the With Factor of text from one attributive block to onother one
eakos1
Message 1 of 20
eakos1
we have usually more headers in one drawings. To save the time to fill all one by one I've created a lisp to do it.
I could manage it - the program is working for content. I used the getpropertyvalue and setpropertyvalue.
Sometimes the name is too long - in this case we setup the with factor of text less than 1 by Text Option.
Is it possible somehow to read and setup this With Factor?
Replies (19)
Message 2 of 20
pbejse
I could manage it - the program is working for content...
Where is the lisp?. we will just modify that to tackle with width issue.
If possible, post a drawing sample.
Message 3 of 20
eakos1
here is the code and the dwg
		    ;Created by Ákos Erdélyi
		    ;This program can take the contant of the selected Company_Header
		    ;and put into the other Headers which are available in the drawing
		    ;v00: 2021.05.03
		    ;:v01: 2021.05.05
		    ;write the customer number into the JSS label too
(defun C:HEADER	(/ *error* s sslen nameMasterEntity dataMasterEntity nameMasterBlock allHeaderSelection	sslenOther c)
   (defun c:test (/ *error*)
      (defun *error* (msg)
	 (if (not
		(member	msg
			'("console break" "Function cancelled" "quit / exit abort")
	    (princ (strcat "\nError: " msg))
	 (princ)
      (rtos
	 (getreal "\nPress Esc to exit, press Enter to force an error ..."
      (princ)
		    ;select the Master Header
   (vl-load-com)
   (setq s (ssget "_:S+." '((0 . "INSERT") (2 . "Company_Header"))))
   (setq sslen (sslength s)) ;- this is always 1
   (setq nameMasterEntity (ssname s 0))
   (setq dataMasterEntity (entget nameMasterEntity))
   (setq nameMasterBlock (cdr (assoc 2 dataMasterEntity)))
		    ;Select all other heaters, remove the Master from the selection set
   (setq allHeaderSelection (ssget "x" '((0 . "INSERT") (2 . "Company_Header"))))
   (ssdel nameMasterEntity allHeaderSelection) ;Remove the Master from the list
   (setq sslenOther (sslength allHeaderSelection))
		    ;read and write the data
   (setq c 0)
   (repeat sslenOther
      (setq HeaderName (ssname allHeaderSelection c))
      (setpropertyvalue
	 HeaderName
	 "DESCRIPTION"
	 (getpropertyvalue nameMasterEntity "DESCRIPTION")
      (setpropertyvalue
	 HeaderName
	 "ITEM"
	 (getpropertyvalue nameMasterEntity "ITEM")
      (setpropertyvalue
	 HeaderName
	 "DRAWING"
	 (getpropertyvalue nameMasterEntity "DRAWING")
      (setpropertyvalue
	 HeaderName
	 "CUSTOMER"
	 (getpropertyvalue nameMasterEntity "CUSTOMER")
      (setpropertyvalue
	 HeaderName
	 "ORIGINATOR"
	 (getpropertyvalue nameMasterEntity "ORIGINATOR")
      (setpropertyvalue
	 HeaderName
	 "DATE_DESIGN"
	 (getpropertyvalue nameMasterEntity "DATE_DESIGN")
      (setq c (1+ c))
   )		    ;end repeat
		    ;Here will the program the customer number write in the JSS standard lable
   (if
      (setq selectionLable
	      (ssget "x"
		     '((0 . "INSERT") (2 . "5445_PRT-GLO-5113_TAKGEN_Master"))
	(progn
	   (setq nameLable (ssname selectionLable 0))
	   (setpropertyvalue
	      nameLable
	      "ITEMC"
	   (setpropertyvalue
	      nameLable
	      "CUST_PART_NO"
	)	    ;end progn
   )		    ;end if
   (princ "\nCreated by Ákos Erdélyi.Thanks for using my program.")
   (princ)
)		    ;end defung
Message 4 of 20
eakos1
Here is the header
Message 5 of 20
pbejse
If i read the program correctly, IT copies the values of these TAGS from the selected block to the rest of the same block names
("DESCRIPTION"  "ITEM" "DRAWING" "CUSTOMER" "ORIGINATOR" "DATE_DESIGN")
But now you want to include the width (ScaleFactor) yes?
Its just faster if I create new code, After this i will look at your code thoroughly and modify that.
(defun C:HEADER ( / TagList AttProp s allHeaderSelection atvSource i f tagValue selectionLable nameLable desCustomer)
(setq TagList '("DESCRIPTION"  "ITEM" "DRAWING" "CUSTOMER" "ORIGINATOR" "DATE_DESIGN")
      AttProp '("Tagstring" "Textstring" "ScaleFactor"))
	(if (and
		(setq s (ssget "_:S+." '((0 . "INSERT")(66 . 1) (2 . "Company_Header"))))
		(setq allHeaderSelection (ssget "_X" '((0 . "INSERT")(66 . 1)(2 . "Company_Header"))))
	    (progn
	      (setq atvSource (mapcar '(lambda (at)
			 (mapcar '(lambda (v)
				    (Vlax-get at v)) AttProp
		     (Vlax-invoke (vlax-ename->vla-object (ssname s 0)) 'GetAttributes)))
	      (ssdel (ssname s 0)  allHeaderSelection)
	      (repeat (setq i (sslength allHeaderSelection))
		(foreach itm (Vlax-invoke (vlax-ename->vla-object
					    (ssname allHeaderSelection (setq i (1- i))))
				  			'GetAttributes)
		  (if
		    (and
		      (member (setq tagValue (vla-get-tagstring itm)) TagList)
		      (setq f (assoc tagValue atvSource ))
		    (mapcar '(lambda (prop value)
		      			(Vlax-put itm prop value))
			    	(cdr AttProp) (cdr f)))
	      (if
		(And
		      (ssget "x"
		    (setq desCustomer (cadr (assoc "CUSTOMER" atvSource)))
			(progn
			  (setpropertyvalue nameLable "ITEMC" desCustomer)
			  (setpropertyvalue nameLable "CUST_PART_NO" desCustomer)
  (princ)
HTH
Message 6 of 20
eakos1
Thanks for helping me. 🙂
This is an label. "5445_PRT-GLO-5113_TAKGEN_Master"
To here only the item number and customer number should be transported.
"ITEMC"   "CUST_PART_NO"
But her the width factor is not important- it should stay as it is.
By headers problem can happen only by the "DESCRIPTION" so only here is the width factor important.
By the rest the number of the digits are fix.
I attached the file which contains now the label too.
Message 7 of 20
pbejse
I see, right now it does copy even the width for all the attributes the "Company_Header"block, let me modify the code. is there any particular reason why you're not using Visual lisp funtions? Do you want to stick with vanilla? or are you okay with using VL?
Refer to attached lisp file [ HEADER.lsp ]
Message 8 of 20
Sea-Haven
This was written for auto layout creation so get lots of layouts with a blank title block, so edit 1 and copy to all the others.
; simple update block attribute across all layouts
; By Alan H Nov 2020
(defun c:attall ( / tabs lst x y attnum tabname att bname)
(setq tabs (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
(setq blk (vlax-ename->vla-object (car (entsel "\nPick title block "))))
(setq atts (vlax-invoke blk 'getattributes))
(setq lst '())
(foreach att atts
(setq lst (cons (vla-get-textstring att) lst))
(setq lst (reverse lst))
(setq bname (vla-get-name blk))
(vlax-for lay tabs
  (setq x (vla-get-taborder lay))
  (setq tabname (vla-get-name lay))
  (if  (/= tabname "Model")
    (progn
	(setq attnum -1)
      (setvar "ctab" tabname)
      (IF  (setq ss (ssget "X" (list (cons 0 "INSERT")(cons 410 tabname)(cons 2 bname))))
        (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS 0 )) 'getattributes)
             (vla-put-textstring att (nth (setq attnum (1+ attnum)) lst))
(princ)
(c:attall)
 Its a global style routine just copies all attributes as is.
Message 9 of 20
eakos1
I tried but this is not working by me
Message 10 of 20
eakos1
Thank you, it works fine. 🙂
Answering your question I stared programing in AutoLISP not so log time ago and as beginner I could do it this way. Only this is the reason for vanilla. I'm OK with this code.
Message 11 of 20
pbejse
Good for you @eakos1
I can still post a vanilla version if you want to study it. Just let me know.
Message 12 of 20
eakos1
If you would do it it would be very nice.  Yes, I would be happy if I could study it. 🙂
Message 13 of 20
pbejse
Vanilla flavour it is.
Weird, regardless of browser/computer/Laptop i use, the "Drag files" does not show to enable me to attached a file, sometimes its there, sometimes NOT. Weird.
Is it just me?  Anways. I hope the issue goes away so i can attach the file later. Dont want to clutter the board with codes. It's only going to cause confusion.
Later
Message 14 of 20
eakos1
Same issue by me too.
My experience is that if I want to reply then it is not possible to attache a file.
If I create here a new post I can attache the file.
Message 15 of 20
pbejse
That actually works! Good one @eakos1
HYG.
Refer to attached lisp file [ Vanilla Header.LSP ]
Message 16 of 20
eakos1
Hello, I have to rewrite my program. Until now, we had only one header, but from now on we will have more.
Its name will be Genthem_header_01,  Genthem_header_02, Genthem_header_03 ........
Here is the original code for the selection: at first the sample and all available header in the drawing
(setq s (ssget "_:S+." '((0 . "INSERT") (66 . 1) (2 . "Gentherm_Header"))))
(setq allHeaderSelection (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . "Gentherm_Header"))))
The first line I can rewrite, add a * to the name so I can select all header whatever number is at the and
(setq s (ssget "_:S+." '((0 . "INSERT") (66 . 1) (2 . "Gentherm_Header*"))))
I stacked by the second line. I have to get the full name of the header.
(cdr (assoc 2 (entget (ssname s 0))))  result: "Gentherm_Header_01"
If I replace the text it gives an error
(setq allHeaderSelection (ssget "_X" '((0 . "INSERT") (66 . 1) (2 . (cdr (assoc 2 (entget (ssname s 0)))) ))))
Is it possible to read and add the name somehow to the ssget filter?
Message 17 of 20
komondormrex
you cannot quote lisp expression.
try it that way
(setq allHeaderSelection (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (cdr (assoc 2 (entget (ssname s 0))))))))
Message 18 of 20
eakos1
unfortunatelly the same result
I tried a variable too but it also not works.
(setq Header_name (cdr (assoc 2 (entget (ssname s 0)))))
(setq allHeaderSelection (ssget "_X" '((0 . "INSERT") (66 . 1) (cons 2 Header_name) )))
Message 19 of 20
eakos1
sorry, my first reply was wrong, it works !
Message 20 of 20
john.uhden
@eakos1 ,
The obvious problem in that snippet is that your are trying to use a quoted list that contains a cons...
should be:
(setq allHeaderSelection (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 Header_name) )))
John F. Uhden
