compare 2 blocks attributes values
24 REPLIES 24
Message 1 of 25
sergiu_ciuhnenco
1247 Views, 24 Replies
Hi everyone, I have an idea but , is gonna be made only with your help ...
I have 2 blocks with attributes , I have to compare each cell value in first block with its opposite cell value in other block , and choose the maximum cell value
the blank cell we should consider 0 value ...
for a newbie is hard to made this
Hope on your help !
P.S. we can create a third block , for the maximum value ( make a copy of one of block , and there put the maximum values )
24 REPLIES 24
Message 2 of 25
hmsilva
in reply to: sergiu_ciuhnenco
Hi Sergiu,
It would be easier if all cells have attributes, and TAGs were common to both...
But, with this situation, all TAG's are different, and not all cells have attributes, the number of attributes are different in both blocks, but the blocks are similar, what occurs to me is to store in two lists, the relative position from each Att (from the block insertion point to text insertion point) and the tag/value, and use the relative position, with some fuzz, to test the value, and save the relative position and maximum value in a third list...
Hope this helps,
Henrique
Message 3 of 25
Try this code. As has been said by Henrique, its somewhat unnecessarily complicated, so I tried to simplify.
You need to prepare your drawing first... see the attachment. Copy the tables on top of each other, align them and explode them. Then you can run the lisp.
Spoiler
(vl-load-com)
(defun c:MaxAttTable ( / *error* doc oVAR ss i pt ssi n0 n1 endel point name)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (foreach e oVAR (setvar (car e) (cdr e)))
    (vla-endundomark doc)
    (princ))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (foreach e '(CMDECHO ORTHOMODE OSMODE ATTREQ)
    (setq oVAR (cons (cons e (getvar e)) oVAR)))
  (setvar 'CMDECHO 	0)
  (setvar 'ORTHOMODE 	0)
  (setvar 'ATTREQ 	0)
  (setvar 'OSMODE 	0)
  (if (and (princ "\nNeed ATTDEFs of exploded blocks placed on top of each other, ")
	   (setq ss (ssget '((0 . "ATTDEF"))))
	   (setq i (sslength ss))
    (progn
      (while (not (minusp (setq i (1- i))))
        (setq pt (cdr (assoc 10 (entget (ssname ss i))))
	      ssi (ssget "_C" pt (polar pt 0.5 3) '((0 . "ATTDEF"))))
        (cond ((= 1 (sslength ssi)))
	      ((and (= 2 (sslength ssi))
		    (numberp (setq n0 (read (vl-string-subst "." "," (cdr (assoc 1 (entget (ssname ssi 0))))))))
		    (numberp (setq n1 (read (vl-string-subst "." "," (cdr (assoc 1 (entget (ssname ssi 1)))))))))
	       (setq endel (ssname ssi (car (vl-sort-i (list n0 n1) '<))))
	       (if (not (equal endel 				; for deleting - if deleted ent is NOT
			       (ssname ss  i)))   		; the current of while loop
		 (setq i (1- i)))				; decrease the index
	       (ssdel  endel ss)
	       (entdel endel))
      	      (T
	       (princ "\nSomething is wrong, problematic texts are marked yellow!")
	       (command "_.CHPROP" ssi "" "_C" 2 ""))))
      (setvar 'OSMODE (cdr (assoc 'OSMODE oVAR)))
      (if (setq point (getpoint "\nSpecify insertion point <don't make a block>: "))
	(progn
	  (setq i 0)
	  (while (tblsearch "block" (setq name (strcat "MyBlock" (itoa (setq i (1+ i)))))))
	  (command "_.-BLOCK"  name "_none" point ss ""
		   "_.-INSERT" name "_none" point 1 "" "")))
  (princ)
Message 4 of 25
hmsilva
Sergiu,
as I said in my previous message, one solution was to use the relative position from each Att ,from the block insertion, to point to text insertion point.
But to use this approach, the blocks must be identical, I did edit the two blocks, to ensure that, in my dwg, both blocks, are identical, I did edit the bloks in the Block Editor, and scale both, to the same size.
The following quick and dirty 'demo', sorry but I don't have much spare time to write a cleaner code, is just one possible approach to make the comparison between both blocs...
(vl-load-com)
(defun c:demo (/ ATT BLK INS_PT L1 L2 L3 LAST_E LST OBJ PT SS)
   (if (and (princ "\n Select the two blocks: ")
            (setq ss (ssget '((0 . "INSERT") (2 . "MyBlock1,MyBlock2") (66 . 1))))
            (= (sslength ss) 2)
            (setq pt (getpoint "\ Enter point to insert the result: "))
            (setq last_e (entlast))
      (progn
         (setq obj    (vlax-ename->vla-object (ssname ss 0))
               ins_pt (vlax-get obj 'insertionpoint)
               blk    (vla-get-effectivename obj)
               l1     (mapcar
                         '(lambda (att)
                             (cons (mapcar '- (vlax-get att 'insertionpoint) ins_pt) (vla-get-TextString att))
                         (vlax-invoke obj "GetAttributes")
               obj    (vlax-ename->vla-object (ssname ss 1))
               l2     (mapcar
                         '(lambda (att)
               l1     (vl-remove-if
                         '(lambda (x)
                             (vl-some '(lambda (y)
                                          (if (equal (car x) (car y) 3.5)
                                             (setq l2 (vl-remove y l2)
                                                   l3 (cons (if (> (atof (vl-string-subst "." "," (cdr x))) (atof (vl-string-subst "." "," (cdr y))))
                                                               x
                                                               y
                                                            l3
                                      l2
                         l1
               lst    (append l1 l2 l3)
         (command "-insert" blk "_Scale" 1 pt 0)
         (command "_.explode" "_L")
         (setq ss (ssget "_P" '((0 . "ATTDEF"))))
         (command "_.erase" ss "")
         (foreach x lst
            (entmake
               (list
                  (cons 0 "TEXT")
                  (cons 100 "AcDbText")
                  (cons 40 2.5)
                  (cons 10 (mapcar '+ (car x) pt))
                  (cons 1 (cdr x))
   (princ)
Hope this helps,
Henrique
Message 5 of 25
sergiu_ciuhnenco
in reply to: hmsilva
Thanks guys for fast attempting ,Henrique  your code give in final an error , somethings is goin wrong
Message 6 of 25
hmsilva
@sergiu_ciuhnenco wrote:
...Henrique  your code give in final an error , somethings is goin wrong
Did you try the code with the dwg I've attached?
I did test the code with the dwg I've attached, without error...
Henrique
Message 7 of 25
... code give in final an error , somethings is goin wrong
Are you having non-english version of autocad? If so, add "_." like this...
(command "_.-insert" blk "_Scale" 1 pt 0)
Message 8 of 25
sergiu_ciuhnenco
It show me this kind of thing : "; error: Function cancelled "
I use the dwg file that you atached , write demo comand , selecting the 2 blocks , and when I have to insert the point : error ..
May be I am doing something different from your steps ?
Message 9 of 25
hmsilva
in reply to: ВeekeeCZ
Hi BeekeeCZ,
probably is that what is causing the error...
Thank you
Henrique
Message 10 of 25
sergiu_ciuhnenco
now , it's english version
Message 11 of 25
hmsilva
What is the error?
Henrique
Message 12 of 25
sergiu_ciuhnenco
Message 13 of 25
hmsilva
Invalid... It is not sufficient to understand the error...
Just for debugging:
  • Open the file I did post
  • appload the demo1.lsp
  • type demo
  • select both blocks
  • pick a point
It worked as expected?
Henrique
Message 14 of 25
sergiu_ciuhnenco
same thing , I will try tomorow at work in 2013 version ,, for me is the first time when is happening something like this
I let you know already tomorow , hope with good news
Message 15 of 25
hmsilva
Ok!
I did test the code in AutoCAD 2010, 2012, 2014 and 2016...
Try the attached code, and see if it works better.
Henrique
Message 16 of 25
ВeekeeCZ
@hmsilva wrote:
Hi BeekeeCZ,
Thank you
Henrique
Hi Henrique, you're welcome. I tried your code as well (AutoCAD 2015 EN) and it's fine with me.
Message 17 of 25
hmsilva
@ВeekeeCZ wrote:
.. I tried your code as well (AutoCAD 2015 EN) and it's fine with me.
Thank you, BeekeeCZ, for testing the code also.
It's a weird error, and I can't understand what may be causing the error.
Cheers
Henrique
Message 18 of 25
sergiu_ciuhnenco
finaly , It work :Thanks a lot
both of you do a great job , thanks again !!!!!!!
nice to meet profesionals like you guys !!!!!!!!!!!!
Message 19 of 25
hmsilva
Finaly!!! 🙂
You're welcome, Sergiu!
Henrique
Message 20 of 25
ВeekeeCZ
Cheers
Henrique
Congrats! 🙂 I had ATTREQ 0 from previous... so didn't see that coming.
BTW (error nil) is new to me, nice. Thx
Forma Design Contest
AutoCAD Beta
