Place Text At Block
Place Text At Block
HR2323
Place Text At Block
HR2323
I need lisp to keep place text where block. Place text select option two type, first layer wise and second block name wise.
ВeekeeCZ
Try this...
(defun C:BlkLayLabel ( / ss ts n)
  (if (and (princ "\nNeed blocks,")
	   (setq ss (ssget '((0 . "INSERT"))))
	   (setq ts (getvar 'TEXTSIZE)))
    (repeat (setq n (sslength ss))
      (entmakex (list (cons 0 "TEXT")
		      (assoc 10 (entget (ssname ss (setq n (1- n)))))
		      (cons 40 ts)
		      (cons 1 (cdr (assoc 8 (entget (ssname ss n)))))
  (princ)
(defun C:BlkNameLabel ( / ss ts n)
		      (cons 40 ts)
		      (cons 1 (cdr (assoc 2 (entget (ssname ss n)))))
  (princ)
HR2323
Thank you sir its work, can you add little bit more changes, text height "2", and text justification middle center.
ВeekeeCZ
Ok, then try this code.
Spoiler
(defun C:BlkLayLabel ( / ss en n)
	   (setq ss (ssget '((0 . "INSERT")))))
      (setq en (entget (ssname ss (setq n (1- n)))))
		      (assoc 10 en)
		      (cons  11 (cdr (assoc 10 en)))
		      (cons  40 2)
		      (cons   1 (cdr (assoc 8 en)))
		      (cons  72 1)
		      (cons  73 2)
  (princ)
(defun C:BlkNameLabel ( / ss en n)
		      (assoc 10 en)
		      (cons  40 2)
		      (cons   1 (cdr (assoc 2 en)))
		      (cons  72 1)
		      (cons  73 2)
  (princ)
HR2323
Thank you very much, This time lisp has perfectly work.
